  • 0
Taito Type X and Hyperlaunch 3.0
langersld
Question
I just wanted to get clarification that Taito Type X is working fine in the New RocketLauncher...
In the PC Launcher.ini...I am pointing the script to the bat files
eg:
[super Street Fighter IV]
Application=C:\Hyperspin\Games\Taito Type X\Super Street Fighter IV\Super Street Fighter IV.bat
AppWaitExe=game.exe
I seem to be getting an issue where the game starts fine but after 20 seconds closes and the Hyperlaunch "now loading page appears"
Any help appreciated
  • Answers 1.4k
The Taito X theme the same one available here(on ftp) but I removed the girl that I was not familiar with and replaced it with the artwork found inside the kofxiii theme(also available here). Silenthill Theme was a quick and dirty placeholder I made. I cant share it because it would not pass approval here and I believe its against the rules to post unapproved themes. Video was from youtube, i just downloaded it and chopped it.
But if you share a link on your youtube clip that isn't against the rules. :)
Thanks superrama, it's a pretty good HOTD clone. I liked this comment "Silent Hill Arcade is like playing vomit"- Destructoid.
For those who don't know, you can run it from 3 different exe's, if you want a cross hair then use "Game Loader All RH.exe" as running it with KSHG.exe didn't give me a cross hair.
:cheers:
Hi,
I have a strange problem with SSFIVAE, when i exit the game, the hyperspin resolution is in 640x480 and my desktop is in 1024x768.
So i see a little hyperspin + a part of my windows desktop.
(I had the same problem with raiden 3/4 but for some reason it's solved)
Does this silent hill crash for anybody else or just me?
Mine did at first, only using Game Loader All RH.exe. It crashed right before the first intro. But when I ran KSHG.exe worked. I eventually just kept testing changing the TTX.ini file. I chose this rather then the Game Loader Config.exe cause there was WAY too many ?'s. Essentially all i did was cycled (changed,saved, repeated) through the LoaderMode's, verified my resolution was set, and turned off FPS. I have no idea why that worked... like most of my TTX experiences.
Also got Raiden IV with bezel working... so it's been a good day.
Now I'm trying to figure out how to get Pre-2007 Half-Life 2 materials (the 3 gcf files working). My brain is fried from today, so any guidance would be appreciated.
@Klizine
That is exactly where it's crashing for me too, will try your fix later today :)
@Langersld
Yes mate, I have those codecs installed.
Still, at least I got RIV working in my bartop build thanks to the awesome Gigapig :)
If I can, I'll sort out the files and offer an alternative for those of us that cannot get the ftp standard RIV files to work.
Sent from my SM-N9005 using Tapatalk
sig2.png?raw=1sig.jpg?raw=1
Thanks for finding it and putting in the work to get it going! I had the usual troubles, but like gigapig, I messed with the TTX.ini file (no idea what I changed - made some good guesses I suppose) and am running it through the KSHG.exe, but want a cursor so I will try switching it tomorrow. Also, for anyone having trouble with it crashing, get the installer (exe) for those codecs. I did the ZIP which allowed for batch installs and had issues. Ran the actual installer, and viola!
Is there a way to make the TTX.ini in all English? I did notice it have some kind of request for a language ini so I am assuming it can be done, maybe? I tried to download some language.ini files but instead of ???????? they show ERROR.
Is there any way to add a second player? The config.bat has controls for both my guns and the keyboard but only an entry for 1P, no 2P.
When I added it to Hyperlaunch and tested it, I got an error that an entry was added for me to fill in. My PClauncher.ini had a new piece marked:
[config]
Application=
I just re-entered the path for the application and that did it, but why would it need it twice?
Thanks again!
Rich
I've spent quite a while working with this newer loader, and it does have certain benefits, like forcing a game into windowed mode, etc.
Here is the translated TTX.ini. The main part is at the very top "Loadermode=" then you choose a number from the examples above the entry. The additional features further down the ini, depend on which loader mode you have chosen.
If anyone has made changes to it, to get Silent Hill working without crashing, please post those, thanks. Mine didn't crash, but I haven't yet installed the codec.
I'll put this in my ftp as well.
;/ / I set the LoaderMode this item.
;/ / LoaderMode = -1 + general-purpose frame limiter
;/ / LoaderMode = 0 single-function
;/ / LoaderMode = 1 general purpose
;/ / LoaderMode = 2 SoftTnL + Kof98 TestMode
;/ / LoaderMode = 3 SoftTnL + FXAA
;/ / Full screen LoaderMode = 4 desktop resolution
;/ / ( Not supported on the screen rotation function ) LoaderMode = 5 resolution
change corresponding full screen
;/ / ( You may have some effect when wing God is heavy in LoaderMode other )
LoaderMode = y low spec PC wing God -only setting
[Loader]
LoaderMode = 5
; (Using a 0 usually invalid , should be 1 enabled when playing 5 Hot Gimmick ) you
can use the old Typex Loader
; If you are a key setting in the game of hot gimmick other than 5 , set to be
discharged Loader after startup " Typex Config.exe " .
; * Supports state of the gaming device , because it conforms to the specifications
for the old Typex Loader
; * In spite of the set in TypeX Config.exe, there are problems such as that does not
react during the game .
; * Assign keyboard settings in TypeX Config.exe, should be set properly "Responding
Pad.ini also Otomedius " attached , if no use still , either change the game pad in
that case .
; * Key set of hot gimmick 5 , because it is remapped in Loader side , the setting is
not required .
[Loader Old]
Enable = 0
;/ / This item is compatible with the following LoaderMode .
;/ / LoaderMode = 0
;/ / LoaderMode = 1
;/ / LoaderMode = 2
;/ / LoaderMode = 3
;/ / LoaderMode = y
; I set the window size of the game after starting .
; I can start the window resizing tool button Press and hold to go mouse or CTRL +
F11.
; Setting = 1 ( window settings 1), Setting = 2 ( window setting 2 )
[Window Size]
Setting =
; Window setting 1
[Window Size 1]
Width =
Height =
; Window setting 2
[Window Size 2]
Width =
Height =
;/ / LoaderMode = 0
;/ / LoaderMode = 1
;/ / LoaderMode = 2
;/ / LoaderMode = 5
; The Loader startup , I will automatically start the iccaemu and e-amuemu. 0
disabled , 1 enabled .
[AutoRun]
Enable = 0
; The Loader at the end , I will end the automatic iccaemu and e-amuemu. 0 disabled ,
1 enabled .
[AutoClose]
Enable = 0
;/ / This item is compatible with LoaderMode of all .
; I can change the hot key state of the Loader startup . 0 disabled , 1 enabled .
; When I start up in disabled state , it is enabled by pressing the Pause key .
[Hotkey]
Enable = 1
; I disabled startup WIN key of left and right .
[WinKey]
Disable = 1
;/ / LoaderMode = 0
;/ / LoaderMode = 1
;/ / LoaderMode = 2
;/ / LoaderMode = 3
;/ / LoaderMode = y
; ( Activation key is CTRL + conversion key ) which are written in (ms) the interval
of continuous full-screen Capture program ` ¬ time
; * 10000ms) * ms unnecessary , only fill in the number , 10 seconds to 1000ms ,
100ms 1 second 0.1 second example
[FullScreen Capture]
Interval = 1000
; ( Activation key is CTRL + non-conversion key) are written in (ms) the interval of
continuous game screen Capture program ` ¬ time
[GameScreen Capture]
Interval = 1000
; ( Activation key is CTRL + S) which can be written in (ms) the slide show interval
of BG image
[slideshow]
Interval = 5000
; ( This is a rather vague function) that can be written in (ms) the update interval
of the mouse right-click roll frame advance function
[Frame Advance]
Interval = 0
; SilentHill: The Arcade of play at the time , I described in (ms) the update
interval of the left mouse button fire function .
[Rapid Fire Mouse]
Delay = 0
Interval = 30
; You can set the window size of the enlarged window (Home key )
[Magnifier1]
Width = 640
Height = 480
; Sets the window size of the mouse cursor tracking expanding window (CTRL + Home key
[Magnifier2]
Width = 640
Height = 480
; I want BG image display tool launch configuration of the Loader startup . 0
[bGImage]
Enable = 0
; You can set the display color of the " Insert key " Insert the specified color in
the margin of the game off-screen .
[bGColor]
Color = 000000
; Konami music -based games for some , you need to set to start by directly
specifying the argument or executable file name . 0 disabled , 1 enabled .
[Commandline]
Enable = 0
Run =
; Mode switching from the right-click pause function . 0 disabled , 1 enabled .
[PauseMode2]
Enable = 0
; I will restore to Loader at the end of minimized windows in Loader startup . 0
[Restore Window]
Enable = 1
; Loader after the boot process I go to the secondary monitor the BG image tool and
the game window . 0 disabled , 1 enabled .
[Move Window]
Enable = 0
; Mouse cursor becomes idle for 3 seconds , and then hiding automatically. 0 disabled
, 1 enabled .
[Hide Mouse Cursor]
Enable = 0
; The Continuous Capture program ` ~Yamodo upon activation , I will sound the shutter
sound . 0 disabled , 1 enabled .
[shutter Sound]
Enable = 1
; I read the Pad.ini to Loader startup . 0 disabled , 1 enabled .
[Padini]
Enable = 1
;/ / Set of 5 ----------------------------- relationship Taisen Hot Gimmick
; I set the size of the Mahjong board that is displayed by default . Small 0 , 1, 2
large .
[Mahjong Board]
Size = 1
; I set the BG color of Mahjong board that is displayed by default . Default blank .
; Please enter the color code of 6 digits . White black transparent 000001 , in
000000 , in FFFFFF. * I do not mind even directly specify red, green, blue, yellow ,
etc. , the color .
Color = 000001
; I start the mahjong board automatically . 0 disabled , 1 enabled .
Autorun = 1
; Mahjong board choice when you want to auto-start . Mahjong board only 0 , 1 Mahjong
board + ` touch panel .
MahjongBoard = 1
; ` Touch panel created Nanchatte
; Default settings (1440x1080 window size of the game) Full HD monitor .
; Width of one tile 1 .
PaiWidth = 95
; Height of one tile 1 , the height of the whole .
PaiHeight = 120
; The width of the A ~ `M Pai whole .
PaiAllWidth = 1235
; A ~ `M Pai whole , and the horizontal position from the left .
PaiAllX = 278
; A ~ `N tile whole , vertical position from the top .
PaiAllY = 900
; Horizontal position N tiles , from the left .
PaiNX = 1547
; Transparency of ` touch panel . 1 (Setting range 1 ~ ` 255) * ` touch panel when
creating 150 , etc. , should be in a semi- transparent state usually .
Transparent = 1
;/ / LoaderMode = 5
; * In LoaderMode = -1 is set, may be used in conjunction with UseSpeedHack = 1,
there is a possibility that the frame rate in the game becomes more stable .
; * Adjust the numeric value of " Limit = 59.654 " If you want to sound shift in
music -based games .
[FPS]
Enable = 1
Limit = 59.654
Show = 1
Interval = 75
PosX = 10
PosY = 10
; You to 60fps in that it is set to "1" if -only setting 3 * Game speed Tetris The
Grand Master is fast .
FrameLimitter = 1
;/ / It ( and that do not enable ) LoaderMode = -1
;/ / LoaderMode = 1
;/ / LoaderMode = 2
;/ / LoaderMode = 3
;/ / LoaderMode = 4
;/ / It ( and that do not enable ) LoaderMode = 5
; ***** ***** This setting is valid only New anisotropic filtering (AnisoVersion = 1)
is selected
; Chinese Contra, Half Life2, KOF MIRA, Yokushin, this setting is disabled by ex-
board system .
; * Use as disabled, usually , to LoaderMode setting other than 5 and LoaderMode = -
1, should only be enabled if the game speed is fast .
; * Fuzzy function significant , but might not be in frame 60 and be set to FPSlimit
= 60.
; The change of the number , should be modified as appropriate for your environment .
[TTX]
EnableFPSLimit = 1
FPSlimit = 60.00
;/ / LoaderMode = 3
; 2 -only setting ① Arcana Heart .
UseDDrawColorEmulate = 1
UseDDrawAutoBlt = 0
; ② each game common setting .
UseSpeedHack = 1
SpeedHackMultiple = 10
; ( There is a game that can not start when the "1 " in the Ex-Board system) you can
not start that it is not set to " 1 " in Kof98 why ③
ShowFps = 1
; I operational the mouse cursor in the " CTRL + F11 " window resizing tool ④ on
fire when playing .
UseCursorSet = 1
;/ / LoaderMode = 3
; ① Fxaa feature is exclusive use and ②. Should be "0 " when using the ②. 0 disabled
, 1 enabled .
UseFxaa = 0
; I will emphasize the sharpness of Fxaa is enabled . 0 disabled , 1 mode ①, 2 mode
②
Sharpen = 0
; If you ② enabled, fixes from Sam Sen on AMD environment . I also corrects defects
RaidenIII in Win7 x64 environment .
; It is recommended that you set to " UseSpeedHack = 1 " if the frame rate is not
stable .
ForceSoftwareTransform = 0
;/ / LoaderMode = -1 ( only Konami music -based game)
;/ / LoaderMode = 5
board system .
; This option is Konami music system dedicated game basically . * I will work
correctly only in some games in Type X.
ForceDisplayRefreshRate = 0
DisplayRefreshRateHz = 60
ForceDisplaySize = 0
DisplayMode = 1
DisplayWidth = 1280
DisplayHeight = 1024
;/ / LoaderMode = 1
;/ / LoaderMode = 2
;/ / LoaderMode = 3
;/ / LoaderMode = 4
;/ / LoaderMode = 5
board system .
AnisoVersion = 0
ForceAnisotropicFiltering = 0
MaxAnisotropy = 16
SlowMode = 0
BugFixMode = 1
; * The line of mystery beatmania IIDX 18,19, to Pop'n 19? Line of the mystery will
disappear by setting " AnisoVersion = 0 " to " ForceAnisotropicFiltering = 1 " if
there is .
;/ / LoaderMode = 0
;/ / LoaderMode = 1
;/ / LoaderMode = 2
;/ / LoaderMode = 3
; The thing to be set to " 0" only Sound Voltex and vertical shooting game system ,
you can disable the automatic screen rotation feature . (Add scheduled for 1 enabled)
-1 automatic , 0 Invalid
Rotate = -1
;/ / LoaderMode = 2. 0 disabled , 1 enabled .
ForceWindowed = 1
ForceSoftwareTnL = 0
KofTestmode = 0
;/ / Below This setting is not required from here
UseEffect = 1
ProxyLibrary = d3d9b.dll
DX9Converter = d3d9.dll
Others = 0
Unzip the main HL2 Survivor content dump "HL2AC.zip" (2.7 GB) - this will give you your main Half-Life 2 Survivor game folder
Download a small program called GCFScape and use it to extract the contents of the 3 .gcf files, they will contain the following folder structure:
source_materials.gcf = (root\hl2\materials\<lots of files>)
source_sounds.gcf = (root\hl2\sounds\<lots of files>)
source_models.gcf = (root\hl2\models\<lots of files>)
Copy the 'hl2' folder from each of those and paste it into your main Half-Life 2 Survivor folder (there will already be a hl2 folder in there. IMPORTANT: make sure you say NO to overwriting existing files when asked)
Extract the additional "Ben1066's fixed binaries" (17.6 MB) into your main Half-Life 2 Survivor folder.
Check my FTP folder for a quick/simple launcher (changes resolution to 1360x768 when game is running, hides the Debug Window, restores resolution & closes processes on exit)
Wow, thanks for that! Other than installing the codecs, I changed the width and height from 1920x1080 to something my monitor can handle (way down at the bottom - you have it set in yours to 1280X1024) and I put a 0 for the enable and show of FPS (to disable them). Pretty much what Klizine mentioned he did. I'll check again when I get home to make sure I didn't do anything else because I know I did open that Game Loader Config and was peeking around in there first.
Thanks again!
Rich
I second this...be great to have the inglish ini file it asks...all i see is weird characters i couldnt even possible comprehend...even when drunk xD
i meant for Game Loader Config.exe just in case lol
Care to share TTX.ini file please ?
Here's my ini, which is set to 1080 res.
Thanks Majorspawn for prompting me to look into this, haven't had much time to mess with this one.
Hopefully it should look a little less "foggy" ; )
EDIT: upping the game res doesn't make much if any difference to the way the game looks and it also zooms in the cutscenes.
;//‚±‚̍€–Ú‚ÍLoaderMode‚ðÝ’肵‚Ü‚·B
;//LoaderMode=-1  ”Ä—p + ƒtƒŒ[ƒ€ƒŠƒ~ƒbƒ^[
;//LoaderMode=0   ’P‹@”\
;//LoaderMode=1   ”Ä—p
;//LoaderMode=2   SoftTnL + Kof98 TestMode
;//LoaderMode=3   SoftTnL + FXAA
;//LoaderMode=4   ƒfƒXƒNƒgƒbƒv‰ð‘œ“x‚Ńtƒ‹ƒXƒNƒŠ[ƒ“
;//LoaderMode=5   ‰ð‘œ“x•ύX‘Ήžƒtƒ‹ƒXƒNƒŠ[ƒ“i‰æ–ʉñ“]‹@”\‚ɂ͔ñ‘Ήžj
;//LoaderMode=y   ’áƒXƒyƒbƒNPC—ƒ_ê—pÝ’èi‘¼‚ÌLoaderMode‚Å—ƒ_‚ªd‚¢ê‡‚ÉŒø‰Ê‚ª‚*‚é‚©‚à’m‚ê‚Ü‚¹‚ñj
[Loader]
LoaderMode=5
;‹ŒTypex Loader‚ðŽg—p‚µ‚Ü‚·i’ʏí‚Í0–³Œø‚ÅŽg—p‚µAƒzƒbƒgƒMƒ~ƒbƒN5ƒvƒŒƒCŽž‚Í1—LŒø‚É‚µ‚ĉº‚³‚¢j
;ƒzƒbƒgƒMƒ~ƒbƒN5ˆÈŠO‚̃Q[ƒ€‚ŃL[Ý’è‚ð‚·‚éê‡‚́ALoader‹N“®Œã‚É“f‚«o‚³‚ê‚éuTypex Config.exev‚Őݒ肵‚ĉº‚³‚¢B
;–ƒQ[ƒ~ƒ“ƒOƒfƒoƒCƒX‚̑Ήžó‹µ‚́A‹ŒTypex Loader‚ÌŽd—l‚ɏ€‚¶‚Ü‚·‚Ì‚Å
;–TypeX Config.exe‚Őݒ肵‚½‚É‚àŠÖ‚í‚炸AƒQ[ƒ€’†‚Í”½‰ž‚µ‚È‚¢“™‚Ì•s‹ï‡‚ª‚*‚è‚Ü‚·B
;–‚»‚̏ꍇ‚̓Q[ƒ€ƒpƒbƒh‚ð•ύX‚·‚é‚©A‚»‚ê‚Å‚à‘Ê–Ú‚È‚ç‚ÎTypeX Config.exe‚ŃL[ƒ{[ƒh‚̐ݒè‚ðŠ„‚è“–‚āA“Y•t‚́uƒIƒgƒƒfƒBƒEƒX‚É‚à‘ΉžPad.iniv‚ð“KØ‚ɐݒ肵‚ĉº‚³‚¢B
;–ƒzƒbƒgƒMƒ~ƒbƒN5‚̃L[Ý’è‚́ALoader‘¤‚ÅƒŠƒ}ƒbƒvÏ‚݂Ȃ̂ŁAÝ’è•s—v‚Å‚·B
[Loader Old]
Enable=0
;//‚±‚̍€–ڂ͈ȉº‚ÌLoaderMode‚ɑΉž‚µ‚Ä‚¢‚Ü‚·B
;//LoaderMode=-1
;//LoaderMode=0
;//LoaderMode=1
;//LoaderMode=2
;//LoaderMode=3
;//LoaderMode=y
;ƒQ[ƒ€‹N“®Œã‚̃EƒBƒ“ƒhƒEƒTƒCƒY‚ðÝ’肵‚Ü‚·B
;CTRL+F11‚©ƒ}ƒEƒXi‚Þƒ{ƒ^ƒ“’·‰Ÿ‚µ‚ŃEƒBƒ“ƒhƒEƒTƒCƒY•ύXƒc[ƒ‹‚ð‹N“®o—ˆ‚Ü‚·B
;Setting=1iƒEƒBƒ“ƒhƒEÝ’è1jASetting=2iƒEƒBƒ“ƒhƒEÝ’è2j
[Window Size]
Setting=
;ƒEƒBƒ“ƒhƒEÝ’è1
[Window Size 1]
Width=
Height=
;ƒEƒBƒ“ƒhƒEÝ’è2
[Window Size 2]
Width=
Height=
;//LoaderMode=-1
;//LoaderMode=0
;//LoaderMode=1
;//LoaderMode=2
;//LoaderMode=5
;Loader‹N“®Žž‚ɁAe-amuemu‚Æiccaemu‚ðŽ©“®‹N“®‚µ‚Ü‚·B0–³ŒøA1—LŒøB
[AutoRun]
Enable=0
;LoaderI—¹Žž‚ɁAe-amuemu‚Æiccaemu‚ðŽ©“®I—¹‚µ‚Ü‚·B0–³ŒøA1—LŒøB
[AutoClose]
Enable=0
;//‚±‚̍€–Ú‚Í‘S‚Ä‚ÌLoaderMode‚ɑΉž‚µ‚Ä‚¢‚Ü‚·B
;Loader‹N“®Žž‚̃zƒbƒgƒL[ó‘Ô‚ð•ύXo—ˆ‚Ü‚·B0–³ŒøA1—LŒøB
;–³Œøó‘Ô‚Å‹N“®‚µ‚Ä‚àAPauseƒL[‚ð‰Ÿ‚¹‚ΗLŒø‚ɂȂè‚Ü‚·B
[Hotkey]
Enable=1
;¶‰E‚ÌWINƒL[‚ð‹N“®Žž‚É–³Œø‰»‚µ‚Ü‚·B
[WinKey]
Disable=1
;//LoaderMode=-1
;//LoaderMode=0
;//LoaderMode=1
;//LoaderMode=2
;//LoaderMode=3
;//LoaderMode=y
;˜A‘±‘S‰æ–ʃLƒƒƒvƒ``ƒƒŽž‚ÌŠÔŠu‚ðimsj‚Å‹Lq‚µ‚Ü‚·i”*“®ƒL[‚ÍCTRL+•ÏŠ·ƒL[j
;–—á 0.1•b‚Í100msA1•b‚Í1000msA10•b‚Í10000msj–ms•s—vA”’l‚̂݋L“ü
Interval=1000
;˜A‘±ƒQ[ƒ€‰æ–ʃLƒƒƒvƒ``ƒƒŽž‚ÌŠÔŠu‚ðimsj‚Å‹Lq‚µ‚Ü‚·i”*“®ƒL[‚ÍCTRL+–³•ÏŠ·ƒL[j
Interval=1000
;BG‰æ‘œ‚̃Xƒ‰ƒCƒhƒVƒ‡[ŠÔŠu‚ðimsj‚Å‹Lq‚µ‚Ü‚·i”*“®ƒL[‚ÍCTRL+Sj
[slideshow]
Interval=5000
;ƒ}ƒEƒX‰EƒNƒŠƒbƒN˜A‘ŃRƒ}‘—‚è‹@”\‚̍XVŠÔŠu‚ðimsj‚Å‹Lq‚µ‚Ü‚·i‚©‚È‚èžB–†‚È‹@”\‚Å‚·j
[Frame Advance]
Interval=0
;SilentHill: The ArcadeƒvƒŒƒCŽž‚́Aƒ}ƒEƒX¶ƒ{ƒ^ƒ“˜AŽË‹@”\‚̍XVŠÔŠu‚ðimsj‚Å‹Lq‚µ‚Ü‚·B
[Rapid Fire Mouse]
Delay=0
Interval=30
;Šg‘å‘‹‚̃EƒBƒ“ƒhƒEƒTƒCƒY‚ðÝ’肵‚Ü‚·iHomeƒL[j
[Magnifier1]
Width=640
Height=480
;ƒ}ƒEƒXƒJ[ƒ\ƒ‹’Ç”öŠg‘å‘‹‚̃EƒBƒ“ƒhƒEƒTƒCƒY‚ðÝ’肵‚Ü‚·iCTRL+HomeƒL[j
[Magnifier2]
Width=640
Height=480
;Loader‹N“®Žž‚ÌBG‰æ‘œ•\ަƒc[ƒ‹‹N“®Ý’è‚ð‚µ‚Ü‚·B0–³ŒøA1—LŒøB
[bGImage]
Enable=0
;ƒQ[ƒ€‰æ–ÊŠO‚Ì—]”’‚ÉŽw’èF‚ð‘}“üuInsertƒL[v‚Ì•\ަF‚ðÝ’肵‚Ü‚·B
[bGColor]
Color=000000
;ˆê•”‚̃Rƒiƒ~‰¹ŠyŒnƒQ[ƒ€—p‚ɁAŽÀsƒtƒ@ƒCƒ‹–¼‚âˆø”‚𒼐ڎw’肵‚Ä‹N“®‚·‚éÝ’è‚ð‚µ‚Ü‚·B0–³ŒøA1—LŒøB
[Commandline]
Enable=0
Run=
;‰EƒNƒŠƒbƒNˆêŽž’âŽ~‹@”\‚̃‚[ƒhØ‚è‘Ö‚¦B0–³ŒøA1—LŒøB
[PauseMode2]
Enable=0
;Loader‹N“®Žž‚ɍŏ¬‰»‚µ‚½ƒEƒBƒ“ƒhƒE‚ðALoaderI—¹Žž‚É•œŒ³‚µ‚Ü‚·B0–³ŒøA1—LŒøB
[Restore Window]
Enable=1
;Loader‹N“®ˆ—ŒãAƒQ[ƒ€ƒEƒBƒ“ƒhƒE‚ÆBG‰æ‘œƒc[ƒ‹‚ðƒZƒJƒ“ƒ_ƒŠƒ‚ƒjƒ^‚Ɉړ®‚µ‚Ü‚·B0–³ŒøA1—LŒøB
[Move Window]
Enable=0
;ƒ}ƒEƒXƒJ[ƒ\ƒ‹‚ª3•bŠÔƒAƒCƒhƒ‹ó‘Ô‚É‚È‚é‚ÆAŽ©“®‚Å”ñ•\ަ‰»‚µ‚Ü‚·B0–³ŒøA1—LŒøB
[Hide Mouse Cursor]
Enable=0
;˜A‘±ƒLƒƒƒvƒ``ƒƒƒ‚[ƒh”*“®Žž‚ɁAƒVƒƒƒbƒ^[‰¹‚ð–‚炵‚Ü‚·B0–³ŒøA1—LŒøB
[shutter Sound]
Enable=1
;Loader‹N“®Žž‚ÉPad.ini‚ð“ǂݍž‚݂܂·B0–³ŒøA1—LŒøB
[Padini]
Enable=1
;// -----------------------------‘ΐíƒzƒbƒgƒMƒ~ƒbƒN5ŠÖŒW‚̐ݒè-----------------------------------
;ƒfƒtƒHƒ‹ƒg‚Å•\ަ‚³‚ê‚é–ƒƒ{[ƒh‚̃TƒCƒY‚ðÝ’肵‚Ü‚·B0¬A1’†A2‘åB
[Mahjong Board]
Size=1
;ƒfƒtƒHƒ‹ƒg‚Å•\ަ‚³‚ê‚é–ƒƒ{[ƒh‚ÌBGƒJƒ‰[‚ðÝ’肵‚Ü‚·B‹ó—“‚ŃfƒtƒHƒ‹ƒgB
;6Œ…‚̃Jƒ‰[ƒR[ƒh‚ð“ü—Í‚µ‚ĉº‚³‚¢B000001‚Å“§–¾A000000‚ō•AFFFFFF‚Å”’B–redAgreenAblueAyellow“™AF‚𒼐ڎw’è‚Å‚à\‚¢‚Ü‚¹‚ñB
Color=000001
;Ž©“®‚Å–ƒƒ{[ƒh‚ð‹N“®‚µ‚Ü‚·B0–³ŒøA1—LŒøB
Autorun=1
;Ž©“®‹N“®‚·‚éÛ‚Ì–ƒƒ{[ƒh‘I‘ðB0–ƒƒ{[ƒh‚̂݁A1–ƒƒ{[ƒh{ƒ^ƒbƒ``ƒpƒlƒ‹B
MahjongBoard=1
;‚È‚ñ‚¿‚á‚Á‚ă^ƒbƒ``ƒpƒlƒ‹ì¬
;ƒfƒtƒHÝ’è‚̓tƒ‹HDƒ‚ƒjƒ^—piƒQ[ƒ€‚̃EƒBƒ“ƒhƒEƒTƒCƒY‚Í1440x1080jB
;”v1‚‚̕B
PaiWidth=95
;”v1‚‚̍‚‚³A‘S‘̂̍‚‚³B
PaiHeight=120
;A``M”v‘S‘̂̕B
PaiAllWidth=1235
;A``M”v‘S‘́A¶‚©‚ç‚̉¡ˆÊ’uB
PaiAllX=278
;A``N”v‘S‘́Aã‚©‚ç‚̏cˆÊ’uB
PaiAllY=900
;N”vA¶‚©‚ç‚̉¡ˆÊ’uB
PaiNX=1547
;ƒ^ƒbƒ``ƒpƒlƒ‹‚Ì“§–¾“xB’ʏí‚Í1iÝ’è”͈Í1``255j–ƒ^ƒbƒ``ƒpƒlƒ‹ì¬Žž‚Í150“™A”¼“§–¾ó‘Ô‚É‚µ‚ĉº‚³‚¢B
Transparent=1
;//LoaderMode=-1
;//LoaderMode=5
;–LoaderMode=-1Ý’莞‚ł́AUseSpeedHack=1‚Æ•¹—p‚·‚鎖‚ŁAƒQ[ƒ€’†‚̃tƒŒ[ƒ€ƒŒ[ƒg‚ª‚æ‚èˆÀ’è‚·‚é‰Â”\«‚ª‚*‚è‚Ü‚·B
;–‰¹ŠyŒnƒQ[ƒ€‚ʼn¹ƒYƒŒ‚·‚éê‡‚́uLimit=59.654v‚̐”’l‚𒲐®‚µ‚ĉº‚³‚¢B
[FPS]
Enable=0
Limit=59.654
Show=1
Interval=75
PosX=10
PosY=10
;Tetris The Grand Master 3ê—pÝ’è –ƒQ[ƒ€ƒXƒs[ƒh‚ª‘¬‚¢ê‡u1v‚ɐݒ肷‚鎖‚Å60fps‚É‚µ‚Ü‚·B
FrameLimitter=1
;//LoaderMode=-1i—LŒø‚É‚µ‚È‚¢Ž–j
;//LoaderMode=1
;//LoaderMode=2
;//LoaderMode=3
;//LoaderMode=4
;//LoaderMode=5i—LŒø‚É‚µ‚È‚¢Ž–j
;–––––‚±‚̐ݒè‚͈ٕû«ƒtƒBƒ‹ƒ^ƒŠƒ“ƒONewiAnisoVersion=1j‘I‘ðŽž‚Ì‚Ý—LŒø‚Å‚·–––––
;‚±‚̐ݒè‚́A’†‰ØContraAHalf Life2AKOF MIRAAYokushinAex-boardŒn‚ł͖³ŒøB
;–’ʏí‚Í–³Œøó‘Ô‚ÅŽg—p‚µALoaderMode=-1‚Æ5ˆÈŠO‚ÌLoaderModeÝ’莞‚ɁAƒQ[ƒ€ƒXƒs[ƒh‚ª‘¬‚¢ê‡‚̂ݗLŒø‚É‚µ‚ĉº‚³‚¢B
;–‚©‚È‚è‚ÌžB–†‹@”\‚ŁAFPSlimit=60‚ɐݒ肵‚Ä‚à60ƒtƒŒ[ƒ€‚ɂȂç‚È‚¢‰Â”\«‚ª‚*‚è‚Ü‚·B
;”’l‚̕ύX‚́AŠÂ‹«‚ɍ‡‚킹‚Ä“K‹X•ύX‚µ‚ĉº‚³‚¢B
[TTX]
EnableFPSLimit=1
FPSlimit=60.00
;//LoaderMode=-1
;//LoaderMode=3
;‡@ ƒAƒ‹ƒJƒiƒn[ƒg2ê—pÝ’èB
UseDDrawColorEmulate=1
UseDDrawAutoBlt=0
;‡A ŠeƒQ[ƒ€‹¤’ʐݒèB
UseSpeedHack=1
SpeedHackMultiple=10
;‡B ‰½ŒÌ‚©Kof98‚ł́u1v‚É‚µ‚È‚¢‚Æ‹N“®o—ˆ‚Ü‚¹‚ñiEx-BoardŒn‚ł́u1v‚É‚·‚邯‹N“®o—ˆ‚È‚¢ƒQ[ƒ€‚ª‚*‚è‚Ü‚·j
ShowFps=1
;‡C ‚Ù‚Þ‚çƒvƒŒƒCŽž‚ɁuCTRL+F11vƒEƒCƒ“ƒhƒEƒTƒCƒY•ύXƒc[ƒ‹ã‚Ń}ƒEƒXƒJ[ƒ\ƒ‹‚𑀍ì‰Â”\‚É‚µ‚Ü‚·B
UseCursorSet=1
;//LoaderMode=3
;‡@ Fxaa‹@”\‚͇A‚Æ”r‘¼Žg—p‚Å‚·B‡A‚ðŽg—p‚·‚éê‡‚́u0v‚É‚µ‚ĉº‚³‚¢B0–³ŒøA1—LŒøB
UseFxaa=0
;Fxaa—LŒøŽž‚̃Vƒƒ[ƒvƒlƒX‚ð‹*’²‚µ‚Ü‚·B0–³ŒøA1ƒ‚[ƒh‡@A2ƒ‚[ƒh‡A
Sharpen=0
;‡A —LŒø‚É‚·‚邯AAMDŠÂ‹«‚ŃTƒ€‘M‚Ì•s‹ï‡‚ðC³‚µ‚Ü‚·BWin7 x64ŠÂ‹«‚ÅRaidenIII‚Ì•s‹ï‡‚àC³‚µ‚Ü‚·B
;ƒtƒŒ[ƒ€ƒŒ[ƒg‚ªˆÀ’肵‚È‚¢ê‡‚́uUseSpeedHack=1v‚É‚·‚鎖‚ð‚¨Š©‚ß‚µ‚Ü‚·B
ForceSoftwareTransform=0
;//LoaderMode=-1iƒRƒiƒ~‰¹ŠyŒnƒQ[ƒ€‚̂݁j
;//LoaderMode=5
;‚±‚̃IƒvƒVƒ‡ƒ“‚ÍŠî–{“I‚ɃRƒiƒ~‰¹ŠyŒnƒQ[ƒ€ê—p‚Å‚·B–Type X‚ł͈ꕔ‚̃Q[ƒ€‚ł̂ݐ³í‚É‹@”\‚µ‚Ü‚·B
ForceDisplayRefreshRate=0
DisplayRefreshRateHz=60
ForceDisplaySize=1
DisplayMode=0
DisplayWidth=1920
DisplayHeight=1080
;//LoaderMode=-1
;//LoaderMode=1
;//LoaderMode=2
;//LoaderMode=3
;//LoaderMode=4
;//LoaderMode=5
AnisoVersion=0
ForceAnisotropicFiltering=0
MaxAnisotropy=16
SlowMode=0
BugFixMode=1
;–beatmania IIDX 18A19Aƒ|ƒbƒvƒ“19‚É“ä‚̐üH‚ª‚*‚éê‡uAnisoVersion=0vuForceAnisotropicFiltering=1v‚ɐݒ肷‚鎖‚Å“ä‚̐ü‚͏Á‚¦‚Ü‚·B
;//LoaderMode=-1
;//LoaderMode=0
;//LoaderMode=1
;//LoaderMode=2
;//LoaderMode=3
;cŒnƒVƒ…[ƒeƒBƒ“ƒOƒQ[ƒ€‚ÆSound Voltex‚̂݁u0v‚ɐݒ肷‚鎖‚ŁAŽ©“®‰æ–ʉñ“]‹@”\‚𖳌ø‰»o—ˆ‚Ü‚·B-1Ž©“®A0–³Œøi1—LŒø‚ð’ljÁ—\’èj
Rotate=-1
;//LoaderMode=2B0–³ŒøA1—LŒøB
ForceWindowed=1
ForceSoftwareTnL=0
KofTestmode=0
;//‚±‚±‚©‚牺‚͐ݒè•s—v‚Å‚·
UseEffect=1
ProxyLibrary=d3d9b.dll
DX9Converter=d3d9.dll
Others=0
Anyone got any other tips for getting the sound working on the cut scenes other than installing a different codec? Or did you change the codec settings?
I've installed the suggested but it still does not give sound.
Thanks
Edit: I used the codec installer, when I installed it I deselected the x86 codecs. So I might retry it with all codecs.
Thanks
When it comes to codecs it is always safest to keep the x86 ones as well as the x64 on an x64 system. The x86 applications will revert to whatever the default was but of course it won't see the x64 ones so you may end up with no sound. Minor headache that. Also once you have added the other codecs in do a registry cleanup after reboot and a second reboot. Codecs can be a bitch especially audio. LAV filters also got me pretty annoyed at times as well. *chuckles*
The Silent Hill Arcade cabinet has 5.1 sound. The missing sounds are prob being sent to channels that don't exist on the PC's that are being used to play this. Doesn't seem to be a way of changing it to 2 channel in the test menu (Esc key when using KSHG.exe)
Thanks urban.
No joy with reinstalling the lav filters, I also tried Klite codec pack, AC3 filter and ffdshow; made no difference. I really dislike installing these codec packs and haven't needed to for many years. :(
