Guest gstav Posted January 11, 2011 Posted January 11, 2011 Think he referring to GGG´s ordering page for the Ledwiz where you can specify ID number in the drop box.
granter Posted January 11, 2011 Posted January 11, 2011 Hmm never noticed that before on their order page, so for users that want more than 32 outputs, say like 2 LEDWIZs running of the same computer when you order your LEDWIZ I guess the ID is set by the manufacturer based on what you specify in this drop down? Wonder if this ID can be set by an end user, or if you ordered two LEDWIZ both with #1 could you use them together. And if they do have to be assigned with unique IDs either by the manufacturer or end user can the VP software specify which device to use by ID?
chriz99 Posted January 11, 2011 Author Posted January 11, 2011 I think roger (ext2k) said that 2 ledwiz are not possible with the code. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
shilmover Posted January 11, 2011 Posted January 11, 2011 Right. I would guess its possible to have LED-Wiz #2 be driven by different software.
granter Posted January 11, 2011 Posted January 11, 2011 Right. I would guess its possible to have LED-Wiz #2 be driven by different software. That makes sense, is it only when you order a LEDWIZ from the factory that the #2 or different ID can be set? Or is there a way to set the ID yourself
shilmover Posted January 11, 2011 Posted January 11, 2011 That makes sense, is it only when you order a LEDWIZ from the factory that the #2 or different ID can be set? Or is there a way to set the ID yourself You have to order it that way. In talking to Randy (GroovyGameGear), there is no way to change it after the fact.
mistermixer Posted January 11, 2011 Posted January 11, 2011 have problems with installing this step ledwiz board : and put it on your Visual Pinball tables folder after we need to register it on Windows, go to execute and type: For LedWiz Regsvr32 your tables folderl/Visual Pinball/Tables/ledwizm05.ocx my tables folder is in C/Program Files/Visual Pinball/Tables What is the correct line plz ? Gives error ,can't find module ( but in dutch language :-) )
shilmover Posted January 11, 2011 Posted January 11, 2011 When you run the regsvr32 make sure you put the full path in quotes: Regsvr32 "C:\Program Files\Visual Pinball\Tables\ledwizm05.ocx"
lettuce Posted January 12, 2011 Posted January 12, 2011 Are these the same as the cree leds?? http://www.rapidonline.com/1/1/1348-3w-high-power-rgb-leds-reflow-compatible.html http://cgi.ebay.co.uk/High-power-RGB-led-3-watt-6-pins-3W-RGB-star-/280596836424
chriz99 Posted January 12, 2011 Author Posted January 12, 2011 these leds are no cree's. cree's are high quality, fine selected and ultrabright high power leds. spend the extra bucks, you won't regret it. pay once - cry once cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
shilmover Posted January 12, 2011 Posted January 12, 2011 Are these the same as the cree leds??http://www.rapidonline.com/1/1/1348-3w-high-power-rgb-leds-reflow-compatible.html http://cgi.ebay.co.uk/High-power-RGB-led-3-watt-6-pins-3W-RGB-star-/280596836424 No. These are the same ones I have. They are nice, but not as bright as the Cree (they are also much, much cheaper too). I have some extras...
lettuce Posted January 12, 2011 Posted January 12, 2011 Understood guys! Question, how many Siemens Solonids are you guys running in your cabs, was going to go with 7: 2 flippers 2 slingshots 3 bumpers Hi Lettuce,I can offer you a discount of 5% Wolf how do i go about getting this 5% discount, about to order from your shop?
shilmover Posted January 12, 2011 Posted January 12, 2011 I have 9: - 2 flippers (although they are not connected to the LEDWiz currently - 2 slingshots - 4 bumpers - 1 replay knocker I am using real pinball coils and they are working well (except for the replay knocker. Its not loud enough).
gbeef Posted January 12, 2011 Posted January 12, 2011 these leds are no cree's. cree's are high quality, fine selected and ultrabright high power leds. spend the extra bucks, you won't regret it. pay once - cry once Buy crees... if my resistors come in this weekend ill post a video also. My Cabs My Pin Cab Attack of the PINZ cab My Racing Cab OutRun Racing
shilmover Posted January 12, 2011 Posted January 12, 2011 gbeef, Do you happen to have a direct link to the LEDs you ordered from LEDSupply.com? want to make sure I order the correct one.
reko19 Posted January 12, 2011 Posted January 12, 2011 gbeef,Do you happen to have a direct link to the LEDs you ordered from LEDSupply.com? want to make sure I order the correct one. this is what I used, work great http://www.ledsupply.com/creemce-rgbw.php
lettuce Posted January 12, 2011 Posted January 12, 2011 Whats the difference between the 2 cree stars on this link http://www.led-tech.de/en/High-Power-LEDs-Cree/CREE-MC-E-Series-c_120_133.html 1 sets marked as 316 and the other 342??
chriz99 Posted January 12, 2011 Author Posted January 12, 2011 the 342lumen is coldwhite (take this one for coldwhite clearwhite), the other one is warmwhite with less lumen. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
lettuce Posted January 12, 2011 Posted January 12, 2011 Cheers chris so the 342 would be the better option then. Also would 9w 22Ohm Resistors be the right choice for running the crees at 12volts?
chriz99 Posted January 12, 2011 Author Posted January 12, 2011 Cheers chris so the 342 would be the better option then. Also would 9w 22Ohm Resistors be the right choice for running the crees at 12volts? yes, take the 342lumen. 22ohm 9watt are ok for 12vdc cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
lettuce Posted January 12, 2011 Posted January 12, 2011 yes, take the 342lumen. 22ohm 9watt are ok for 12vdc Well they come in 10, 18 and 22 ohm ratings, i take it the higer the ohm the greater resistance they have? As i can also get hold of some 11w 10ohm resistors, would the 9w ones still be better? Also is it just 1 resistor per cree so id only need 5 resistors, i wouldnt need any for the Siemens Solonids would i? And 1 final thing would a 100watt 8.5amp meanwell psu be enough to power the solenoids etc?? Sorry for all the questions just want to make sure i can get everything from a few places as possible
chriz99 Posted January 13, 2011 Author Posted January 13, 2011 no, take the 22ohm/9watt. you need 1 resistor per color = 4 resistors for 1 cree, if you drive RGBW. for the siemens contactors you need only a diode (I use 1n4007), no resistor. take the 150w 12vdc psu, better for peak current. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
granter Posted January 13, 2011 Posted January 13, 2011 Hey Chris, great cab, question about your flipper buttons, what LED lit ones are you using? I'm using transparent buttons with leaf springs currently. I suppose I could install some kind of lighting for them with LEDs. Wondering if you are using a ready made button solution or just lighting the transparent cabinet ones. Also, what does the lighting give you, does it just let you set the color when the game loads using the ledcontrol software, or do the ROMs actually have in game events that you can light these according to? I imagine it would be neat to have the secondary flippers light when they are active.
