Big Bang Pin - 46/30/15.6 LED Widebody (custom artwork, bezel less, deep playfield)
chriz99
yes, the mirror blades are awesome on real pinball machines.
I think on VP cabinets "smoked" reflective effect looks a bit better, but we should try all available possibilities to get the best effect :D
cheers
chris
[sIGPIC][/sIGPIC]
  • Replies 803
cheers
chris
[sIGPIC][/sIGPIC]
what about some artwork on the backboard to match your sideart, like a real pin would have, yes it would be cab specific but would also give you more of that 3d feel.
CNC Work Here.....
the twilight zone custom sideboard decals are nice. I also like cab specific sideboard idea, but I don't know if it feels "ok" for every table.
here is a cool example for an AFM
rockyrocket seems also be right that a static image flattens the 3D illusion on VP cabs.
so maybe better go the reflective/mirror way - so it's more univeral and give a bit of 3D.... hmmmm
cheers
chris
[sIGPIC][/sIGPIC]
I was playing TOM the other night and thought it was so cool seeing the ball at the top rollovers in a reflection. Immediately I thought of the mirror blades, but didn't want to spend so much for a maybe... I look forward to see your cabinet with the mirrored sides. I think it will add no only flasher reflection, but also increase the depth realism. Hope so!
After helping my friend pick up his IM with the mirror blades over the weekend I decided to try a cheap door mirror just on the sides.
I have not cut glass before so hopefully it will go well. The door mirror, glass cutter and mounting tape are about $12 total. If I don’t like it I am no out much money.
you can also get mirrored plexi/acrylic which cuts easy, so maybe look into that.
CNC Work Here.....
thats a nice idea! acrylic mirror! :beer:
is there also a "dark" acrylic mirror available... like smoked glas?
yup, i have seen smoked mirror also.
CNC Work Here.....
that's the way I wired it:
hi i can see green,violett,blue go to the led stripe thats ok
the red one to the led stripe thats ok
four connetctions thats finished
the input green,violett,blue and red and gray is ok
i go from led wiz rgw to the flipperbuttons rgb led thats came from wolfsoft
and from the same connector from the ledwiz to the 4 Kanal 12V Relais Relay Modul for PIC ARM AVR Arduino
or go i from the ledwiz to the 4 Kanal 12V Relais Relay Modul for PIC ARM AVR Arduino and from there to the flipper button rgb led's and stripes ???
i can see a white cable 3 times for what is this????
and from the same connector from the ledwiz to the 4 Kanal 12V Relais Relay Modul for PIC ARM AVR Arduino...
this way is correct
cheers
chris
[sIGPIC][/sIGPIC]
Installed a microswitch on the coindoor reject-button. Glued it sideways, so you still can use the reject and insert coin function.
cheers
chris
[sIGPIC][/sIGPIC]
The artwork on this one still amazes me. One day I might actually come up with a name and artwork for mine lol.
got some opto relays for a nice price... my cab is now 100% opto controlled :D Ledwiz stays cool and my flashers are now 700ma per output:
switched also to 5v, so I need just 3watt resistors for the flashers.
but it was a real PITA to solder that thing :stupid::stoned:
cheers
chris
[sIGPIC][/sIGPIC]
you must be the real soldering monster then !! :dancing2:
[TABLE=width: 500]
[TR]
[TD][/TD]
[TD=align: center]New project homepage: http://blog.pixelmagic.nl/[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD=align: center]LED-Wiz utility: http://pinball.pixelmagic.nl/ledwiz/[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD=align: center]Anyone want to buy my LEDwiz ??
[/TD]
[TD][/TD]
[/TR]
[/TABLE]
thanks to the optos I drive my backbox and playfield flashers with 350mA each. before was 300mA backbox and 100mA playfield. now they are really flashing :D
if you use original cree rgb led you could drive them with 700ma - for the ultimative FLASH :D
cheers
chris
[sIGPIC][/sIGPIC]
