chriz99 Posted July 7, 2012 Author Posted July 7, 2012 thanks gbeef I am a big fan of multicolor LCD DMDs, but I felt in love with the real DMD - the real glowing effects are just awesome. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
Gigagamesguy Posted July 29, 2012 Posted July 29, 2012 here is an "easy diagram" for T6 strobe wiring, maybe we can use it for pinball101 Woher wissen die 3strobos wieviel mah sie nehmen dürfen die sind ja durch Wiederstände nicht begrenzt, habe das genauso gebaut läuft alles auf 12 Volt http://www.hyperspin-fe.com/forum/showthread.php?16722-New-PowerPin-from-Germany-Tom-46x32x15-6
maxxsinner Posted July 29, 2012 Posted July 29, 2012 Woher wissen die 3strobos wieviel mah sie nehmen dürfen die sind ja durch Wiederstände nicht begrenzt, habe das genauso gebaut läuft alles auf 12 VoltHow do the 3strobos how much they can take mah are not limited by resistors, which have just built everything runs on 12 volts Die Art und Weise Chris seine verdrahtet hat hier GGG ist in Serie. Jede LED hat eine 3,6-Volt-Abfall über sie Approximatley und der Konstantstrom-Treiber schützt vor Überlastung. Sicher, ohne Widerstände zu verwenden. The way Chris has wired his here GGG is in series. Each LED has approximatley a 3.6 volt drop across it and the constant current driver protects it from overload. Safe to use without resistors. Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
njay Posted August 24, 2012 Posted August 24, 2012 Hi Chris, i just got my DMD plasma 12v from vishay , and mameman is currently designing my dmd speaker panel, but how do you mount the dmd? just screw it on the back? do you need spacers etc? can you post a pic of yours plz? thx My Mini Pin Build: http://www.hyperspin-fe.com/forum/showthread.php?t=5622 My Arcade Bartop Build: http://www.hyperspin-fe.com/forum/showthread.php?t=14570
chriz99 Posted August 24, 2012 Author Posted August 24, 2012 I have an orignal Williams Speakerpanel, so I used the original mounting holes. I think you need some (plastic)spacers on a diy speakerpanel, like pcb spacers/holders. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
Captain Canuck Posted September 3, 2012 Posted September 3, 2012 Hi, first time poster. LOVE your work Chris, I am hoping to make something similar to this cabinet size-wise. Was wondering if you were able to fold down the backbox when you had the monitor as your DMD? I see you have the real pinball hinges on there but maybe those were just for realism. Thanks!
chriz99 Posted September 3, 2012 Author Posted September 3, 2012 hey captain canuck yes, you can fold down the backbox, like a real pinball machine. makes it easier to transport. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
Captain Canuck Posted September 3, 2012 Posted September 3, 2012 Ah that's good, I would like to be able to fold that down after I finish the machine and move it inside. I thought maybe the DMD monitor sticking down into the main cabinet might stop it from folding. But I guess it just sticks through by a few inches with that monitor you used? Thanks
mameman Posted September 4, 2012 Posted September 4, 2012 CC, a 15.6" screen like we use is contained in the backbox behind the Dmd panel no need to drop in down into the main cab like you may have to with a 17 or 19 PM me for any custom CNC needs. Find me on Facebook.. Xtreme Pinball or www.xtremepinball.com Ipad pinball cabinet iFlipper Here: See the Doctor Who build Here.... / See the Tron build Here.... / See the BattleStar Galactica build Here.... See the Big Bang Bar build Here.... / See the Twilight Zone build Here.... CNC Work Here.....
Captain Canuck Posted September 4, 2012 Posted September 4, 2012 Ah thanks, didn't realize that. Tried to find a picture of it in the backbox but couldn't. I see Best Buy up here has a 15.6" widesceen which must be the same. I will check out you projects next, thanks MM.
mattdavis Posted September 4, 2012 Posted September 4, 2012 The BestBuy Dynex 15.5" (or so) I purchased has the advantage of auto-starting when AC is turned on (my 32" dynex does as well). -Matt My Build Log
Captain Canuck Posted September 5, 2012 Posted September 5, 2012 Thanks Matt, good to know. Was just going to order one of the 15.6" monitors and I noticed in the description that it's a USB powered and doesn't even need a VGA cable. Never heard of this, are you guys using those features? Or maybe this is not the same monitor.. http://www.bestbuy.ca/en-CA/product/aoc-aoc-15-6-widescreen-led-monitor-e1649fwu-e1649fwu/10191474.aspx?path=026070833be4c6b7606880fe155f8295en02
luvthatapex Posted September 5, 2012 Posted September 5, 2012 No, you need the VGA cable with this monitor.
MTPPC Posted September 5, 2012 Posted September 5, 2012 AOC 15.6" Widescreen LED Monitor (E1649FWU) This portable 15.6-inch widescreen LED-backlit display is the ideal laptop accessory. Add real estate easily with the elegant, ultra-thin AOC E1649FWU. It requires no external power source or VGA cable, because it draws power from your computer's USB plug (which also delivers the video feed). Pivot the built-in stand from portrait to landscape mode to optimize viewability for applications.
Captain Canuck Posted September 5, 2012 Posted September 5, 2012 Sorry guys I missed Chris's description of the monitor in his first post. It's a HannsG and I found it at Tiger Direct up here for $81..good deal I think
mameman Posted September 5, 2012 Posted September 5, 2012 Yeah I have used the Hanns and the aoc true monitor both are great PM me for any custom CNC needs. Find me on Facebook.. Xtreme Pinball or www.xtremepinball.com Ipad pinball cabinet iFlipper Here: See the Doctor Who build Here.... / See the Tron build Here.... / See the BattleStar Galactica build Here.... See the Big Bang Bar build Here.... / See the Twilight Zone build Here.... CNC Work Here.....
Ton Posted September 18, 2012 Posted September 18, 2012 Hello Chris, First compliments with your Big Bang Pin. It sure did inspire me to build a pin cab too! Question: what did you use as fingerguards for the three 220mm Akasa fans. I can see you mounted them on the outside over the Akasa fans. Ton
chriz99 Posted September 19, 2012 Author Posted September 19, 2012 hey Ton, I used some loudspeaker covers (metal mesh) for the akasa fans, check out pollin.de for "lautsprecher schutzgitter" cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
Ton Posted September 21, 2012 Posted September 21, 2012 Thanks. I found them on Ebay.de and will order them the coming weeks. Where did you buy your leaf switches?
chriz99 Posted September 22, 2012 Author Posted September 22, 2012 check out arcadeshop.de - but I think the leafswitches are sold out atm. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
Clark Kent Posted October 13, 2012 Posted October 13, 2012 Best setup I ever saw! Congrats! May I ask total investment for your baby?
chriz99 Posted October 13, 2012 Author Posted October 13, 2012 thanks for your kind words, clark kent! I stopped counting at the 5k mark, so I don't know the exactly costs (gives me a better sleep ) cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
Clark Kent Posted October 14, 2012 Posted October 14, 2012 May I ask what is your profession? From where do you have all the technical knowledge and the professional craftsmanship?
chriz99 Posted October 14, 2012 Author Posted October 14, 2012 I got most knowledge from this forum, reading and reading the internet and a bit help of some local buddies. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
