BadBoyBill Posted December 27, 2012 Author Posted December 27, 2012 This weekend I will open things back up and try to fix any current issues, on a side note I forgot to mention that I had added roms only filter, you can check the box in hq to only show games that you have a Rom for, based on your rom path and rom extensions. Also if HS feels laggy then double check that you do not have quality set to Best, this option affects HS a lot with no considerable difference in rendering appearance from the High setting, everyone should do this if possible
DrMoney Posted December 27, 2012 Posted December 27, 2012 I had that "Roms Only" part checked and it caused a crash on my Sega Saturn and Turbografx CD wheels when I tried to enter them but works fine if I turn those two off. Any helpful info I could give you on that? TUTORIAL!: Xpadder and You If you're super into using genuine controllers for emulation check THIS GUY out.
brolly Posted December 27, 2012 Posted December 27, 2012 I can't test now to check it, but maybe some issue related with the roms being inside sub-folders? Just saying this since it's happening on 2 CD based systems.
DrMoney Posted December 27, 2012 Posted December 27, 2012 That would make sense but it doesn't do that to my Playstation wheel. TUTORIAL!: Xpadder and You If you're super into using genuine controllers for emulation check THIS GUY out.
rgm2000 Posted December 27, 2012 Posted December 27, 2012 @bent98 Yes I already played with it. But no differents for me. So I switched back to HS1.3 and everything is fine now for this moment. I'm going to be patient for BBB's next release. I think he knows enough now. Thanks for helping ;-)
miglea85 Posted December 27, 2012 Posted December 27, 2012 Thank you soo much BBB, very nice work. I must ask. Why dont you upload this version on the download area?
Titanusss Posted December 27, 2012 Posted December 27, 2012 Nice and smooth. The only issue I have is that it asks me for PCLauncher.ini when I try to play a pc game. What's changed from previous version? Thanks a lot.
Circo Posted December 27, 2012 Posted December 27, 2012 Do a search for pclauncher there have been a couple of threads already and a new hyper launch module even. You should be up and running in no time. ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
retroACTIVE Posted December 27, 2012 Posted December 27, 2012 FWIW, I was able to make progress. I uninstalled/re-installed flash and my catalyst drivers. It's working now except in full screen its windowed. Seems like my setup is full of warts... likely of my doing from months of tinkering.
BladeZX Posted December 27, 2012 Posted December 27, 2012 Thanks for the update Seems slower now in Windows 8 than with 1.2. I even tried the 1.3.1 update but no difference. There is a definite delay when it first starts up. It seems to still play the flv and transitions. Does HyperSync now pull the MP4 videos or give us the option to do so? Will it remove the duplicate flv videos? Thanks HyperPin Manager | HyperSpin Manager | HyperSpin Checker | HyperSpin Renamer ASRock Z77 Extreme4 MB | Core i5 3570K | Coolermaster Hyper212 EVO CPU cooler | 16GB RAM | OCZ Vertex 4 128Gb SSD (Windows 8) | OCZ Vertex 4 256Gb SSD (HS and all emulators and media) | Gigabyte GTX670 2Gb video card | 27" ASUS LED monitor | 650W Corsair PSU
megabyte417 Posted December 27, 2012 Posted December 27, 2012 @BladeZX Yes HyperSync will pull the MP4 videos (Circo removed the FLV's upon the HS 1.3 release). Duplicates should also be removed from your video folder.
BladeZX Posted December 27, 2012 Posted December 27, 2012 Sweet Thanks HyperPin Manager | HyperSpin Manager | HyperSpin Checker | HyperSpin Renamer ASRock Z77 Extreme4 MB | Core i5 3570K | Coolermaster Hyper212 EVO CPU cooler | 16GB RAM | OCZ Vertex 4 128Gb SSD (Windows 8) | OCZ Vertex 4 256Gb SSD (HS and all emulators and media) | Gigabyte GTX670 2Gb video card | 27" ASUS LED monitor | 650W Corsair PSU
ghutch92 Posted December 27, 2012 Posted December 27, 2012 The controls for horizontal wheel is acting weird. What it is doing now: I press down a single time it goes to the next game in Z to A order, and if I hold down it goes to the next game in A to Z order. I press up a single time it goes to the next game in A to Z order, and if I hold up it goes to the next game in Z to A order. Left skips by letter in A to Z order, and right skips by letter in Z to A order. Summary of the now: Compared to the normal wheel style up is down, down is up, left is right and right is left. (now vs normal) What horizontal style should do: (most intuitive) I press right a single time it goes to the next game in A to Z order. I press left a single time it goes to the next game in Z to A order. Down skips by letter in A to Z order, and up skips by letter in Z to A order. Summary of the should: Compared to the normal wheel style up is left, down is right, left is up and right is down. (should vs normal) How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
Hyperion Posted December 28, 2012 Posted December 28, 2012 Also if HS feels laggy then double check that you do not have quality set to Best, this option affects HS a lot with no considerable difference in rendering appearance from the High setting, everyone should do this if possible I was getting worried as the update made HS very slow compared to 1.2 but checking high instead of best cleared this up (mostly). Still slightly slower than 1.2 but knocking it back to medium cleared that up with only a slightly noticeable loss of quality. It even made my animation heavy themes run at the intended speed which I'm very happy with! My first cocktail cab: The Hyper Arcade Entertainment System Win 7 64bit | i5 3570K Overclocked to 4.2GHz | 16GB 1600MHz DDR3 | GTX 970 Strix | Samsung 250GB 840 Evo SSD + 8x4TB green drives in RAID 5 for XBMC/KODI
Skeletor101 Posted December 28, 2012 Posted December 28, 2012 Thanks BBB, Haven't noticed any lag and my startup time remains the same (Alienware Aurora i7-3930K) , and the wheel smoothing is awesome, Thanks Again !
BladeZX Posted December 28, 2012 Posted December 28, 2012 Nice and smooth. The only issue I have is that it asks me for PCLauncher.ini when I try to play a pc game. What's changed from previous version? Thanks a lot. Did u figure this out. I get the same thing and I am using the 1.5 version of the script. Thx HyperPin Manager | HyperSpin Manager | HyperSpin Checker | HyperSpin Renamer ASRock Z77 Extreme4 MB | Core i5 3570K | Coolermaster Hyper212 EVO CPU cooler | 16GB RAM | OCZ Vertex 4 128Gb SSD (Windows 8) | OCZ Vertex 4 256Gb SSD (HS and all emulators and media) | Gigabyte GTX670 2Gb video card | 27" ASUS LED monitor | 650W Corsair PSU
ghutch92 Posted December 28, 2012 Posted December 28, 2012 Did u figure this out. I get the same thing and I am using the 1.5 version of the script. Thx If you have a system named pc games. HyperSpin will send the system name "PCLauncher" to HyperLaunch instead of "PC Games". so here is what changed your settings (settings folder) and your modules. Settings Folder PCLauncher.ini contains the settings for HyperLaunch. (it's under [exe info] in your pc games.ini) PC Games.ini contains the settings for HyperSpin. A quick fix would be to copy your PC Games.ini and rename the copy as PCLauncher.ini . HyperLaunch's next version is going to separate its settings files from HyperSpin's settings files. Modules Folder You need to create a new folder in the modules folder named PCLauncher . Place the PCLauncher.ahk and its settings file in the folder you just created. If the System Name is PC Games or PC Launcher HyperSpin and HyperLaunch will not perform a filecheck for an emulator or roms. Meaning no more dummy.exe or blank txt files. How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
retroACTIVE Posted December 28, 2012 Posted December 28, 2012 FWIW, I was able to make progress. I uninstalled/re-installed flash and my catalyst drivers. It's working now except in full screen its windowed. Seems like my setup is full of warts... likely of my doing from months of tinkering. Ok... more experimenting. I'm afraid I'm on an island with my setup, however I thought I would share. I have 1.3.1 running full screen. It has no audio though. I also cannot select a system. It actually behaves as if it has 'no speakers quirk' that I've discovered searching the forums. 1.2 works with audio just fine. I suspect it has something to do with it picking the wrong audio device. I have built in audio on the MB and a secondary on the HDMI connector on my radeon card. I've not connected anything to that HDMI port and I have the default audio source set to the internal realtek audio device. All other sounds work on the pc, it just appears as if hyperspin has not selected the default (or perhaps there is something wrong with my PC's default configuration that I am not aware of). Anyway... that's where I am with this version. It really looks great though and I can't wait to get it working Thanks again.
BladeZX Posted December 28, 2012 Posted December 28, 2012 If you have a system named pc games. HyperSpin will send the system name "PCLauncher" to HyperLaunch instead of "PC Games". so here is what changedyour settings (settings folder) and your modules. Settings Folder PCLauncher.ini contains the settings for HyperLaunch. (it's under [exe info] in your pc games.ini) PC Games.ini contains the settings for HyperSpin. A quick fix would be to copy your PC Games.ini and rename the copy as PCLauncher.ini . HyperLaunch's next version is going to separate its settings files from HyperSpin's settings files. Modules Folder You need to create a new folder in the modules folder named PCLauncher . Place the PCLauncher.ahk and its settings file in the folder you just created. If the System Name is PC Games or PC Launcher HyperSpin and HyperLaunch will not perform a filecheck for an emulator or roms. Meaning no more dummy.exe or blank txt files. Thank you. That seemed to get it running. I was not aware this changed. I just need to figure out the exit from the PC game now since ESC seems to not work anymore. It used to. Do I need to specify for each game in the Settings.ini that I want to use ESC or is there a default somewhere. HyperPin Manager | HyperSpin Manager | HyperSpin Checker | HyperSpin Renamer ASRock Z77 Extreme4 MB | Core i5 3570K | Coolermaster Hyper212 EVO CPU cooler | 16GB RAM | OCZ Vertex 4 128Gb SSD (Windows 8) | OCZ Vertex 4 256Gb SSD (HS and all emulators and media) | Gigabyte GTX670 2Gb video card | 27" ASUS LED monitor | 650W Corsair PSU
Eminem Posted December 28, 2012 Posted December 28, 2012 Ok... more experimenting. I'm afraid I'm on an island with my setup, however I thought I would share.I have 1.3.1 running full screen. It has no audio though. I also cannot select a system. It actually behaves as if it has 'no speakers quirk' that I've discovered searching the forums. 1.2 works with audio just fine. I suspect it has something to do with it picking the wrong audio device. I have built in audio on the MB and a secondary on the HDMI connector on my radeon card. I've not connected anything to that HDMI port and I have the default audio source set to the internal realtek audio device. All other sounds work on the pc, it just appears as if hyperspin has not selected the default (or perhaps there is something wrong with my PC's default configuration that I am not aware of). Anyway... that's where I am with this version. It really looks great though and I can't wait to get it working Thanks again. I tested 1.3 fine on my setup, with a HDMI connected with a radeon card.... no sound issues for me.... windows 7.... it should natively select the sound that window's has selected... all apps run this way, I don't see this being any different.... :x
ghutch92 Posted December 28, 2012 Posted December 28, 2012 Thank you. That seemed to get it running.I was not aware this changed. I just need to figure out the exit from the PC game now since ESC seems to not work anymore. It used to. Do I need to specify for each game in the Settings.ini that I want to use ESC or is there a default somewhere. This issue is related to the PCLauncher Module not Hyperspin. How to fix it Set ExitKey = Process and it should work 9 times out of 10. If the game uses a proxy executable or you don't want to do a hard close change FadeTitle to equal ahk_class "Whatever the Window Class of this Game is" and ExitKey = WinClose. You can get your game's class name using ahk's window spy, djvj's window logger, or dustind900's PCLauncher Settings Creator. How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
chartwel Posted December 28, 2012 Posted December 28, 2012 1.3 seems to have broken a few of my systems, gonna have to tweak them again. the fun begins again
