Don's HyperSpin Tools 4.2.6
emb
Apparently the old version (4.3.19) works on ccd files. I've tested it and that seems to be the case, but the 4.3.19 version ruins .gdi archives. So you can't win really.
Am I right in believing the 7z is the only file that needs to match the xml name or does the cue/ISO/ccd/bin/img etc etc need renaming inside the renamed archive?
This is true for some modules and not true for others, I believe. Either way though, I change everything to be sure.
Want to try and get some more immediate help? Want to procrastinate from whatever productive work you should be doing on your computer by helping others with their retro gaming and emulation hobby? Come and join us on the Official #HyperLaunch-Help on irc.foreverchat.net! Fire up your favorite IRC client or simply click this link: #HyperLaunch-Help Webchat =D
  • Replies 298
7z does not discriminate between modules. It is a function outside the module, so it is the same for all of them. Likewise, so is the naming requirements. Depending on the skipchecks options you set and if you use rom mapping is what determines how strict naming will be.
Sent from my Samsung Galaxy S3 using Tapatalk 4.
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Recommended will always be to match everything to the xml.
If you don't want to match inside files, turn on first matching extension.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
OK great, thanks. I wasn't positive about that.
The zipped file name MUST match the database. Any image using a .CUE file - the cue file name must match the zipped file name. The rest of the image content names won't matter.
Like I said above, you can turn on the first matching extension setting and it will match the first rom with a matching extension from your list of extensions you defined for that emu. So I would put cue closer to the first to match cues before bin or iso for example. If it matches iso and you can't send that to the emu, it will break the launch because the emu might not know how to handle that file.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Im trying to rename all my Sega CD (Redump Sets) and Dreamcast GDI (sets) and Sony Playstation... I jumped into this a little late so Im not sure what progress was made...
can I use this tool to rename from XML files yet?
"I'm not a smart man Jenny, but I no what love is" - Forrest G.
  • 3 weeks later...
Emb, Can you add a option for copy the name of the game selected in Hyperlist ??? with right click mouse ???
Emb has sort of retired...for a good while at least.
Unfortunately I believe that retirement is permanent. He loves programming and doing all the hours at work is fine but then coming home and doing the same thing would kill anyone's love affair.
We can live in hope...
I have asked in that rhread if emb would be willing to share source code. Did not ask for licensing though. No answer yet. Guess when he said retirement he meant retirement :-)
Gesendet von meinem LG-P880 mit Tapatalk
Not really sure where yeh want potential bugs posted so I suppose this is as good as any other. Used ver. 4.3.25 to generate a WonderSwan database using a No-Intro dat and apostrophes were left as such instead of being replace with ' . I'm assuming that wasn't meant to be.
  • 2 months later...
Sorry to revive old thread but i am trying to use this to rename my roms. It seems to work but it keeps outputting them to seperate folders.
Is there a way to have it to either zip the files or not put them in seperate folders?
(I know there is a zip option but only if you copy the files - which doesnt actually seem to work)
  • 1 month later...
  • 1 year later...
index.php?app=downloads&module=display&section=screenshot&id=7876
File Name: HyperTools (Don's HyperSpin Tools)
File Submitter: emb
File Submitted: 07 May 2015
File Category: ROM/Database/Renaming tools
Credits: EMB
Who is up for beta testing? Remember to backup your data before using.
Features for this release include:
ROM Renamer
- New and improved interface
- New and improved fuzzy scanning (supports TOSEC, no-intro goodmerge, roman numerals, and more)
- CD image support (supports cue,ccd,gdi,iso, updates sheets and renames files)
- Collapsable view to see what files are attached to a CD image
- Drag and drop support to manually match games
- Search and filter through your games/lists
- Re-compress your renamed files to zip
- Capability to specify more than one ROM folder
- Resizable and collapsable panels
- Option to specify temp folder to help minimize thrashing of the hard drive.
List Filter (previously known as list generator
- Editable fields
- Preview artwork
HyperList Converter (Dat to XML)
- Convert a ROM directory to an HyperList XML (a ROM2XML replacement)
- Convert a mamelist.xml file to a HyperList XML
HyperList Merger
- option to not have an exe tag
(Beta has been renamed to HyperTools)
http://honerbrink.com
I liked this post.  ;)
But none of the links work.  :(
Got a little happy here, thought maybe a new version?  Or a link to the current?
Thanks,
Ron
  • 1 month later...
The Hyperlist Converter doesn't let me choose a folder so I can make an XML file. It just wants a DAT file. Did I miss something or did I do it wrong? I just want to make an XML file for the games I have.
If you are using RocketLauncher, RLUI can do it for you as well.  Select the system on the left you want to create a DB for.  At the top click on Emulators.  Right below that is an icon that says "Generate Database...".
With Don's tools, you have to use the program called "Create New HyperList.exe".  Sounds like you have an older version of Don's tools.  The most up-to-date version is 4.3.25.
Thanks,
Ron
Is there a link to the 4.3.25 version?  Every link I have tried only takes me to the 4.2.6 version. Thank you :)
