  • 0
Taito Type X and Hyperlaunch 3.0
langersld
Question
I just wanted to get clarification that Taito Type X is working fine in the New RocketLauncher...
In the PC Launcher.ini...I am pointing the script to the bat files
eg:
[super Street Fighter IV]
Application=C:\Hyperspin\Games\Taito Type X\Super Street Fighter IV\Super Street Fighter IV.bat
AppWaitExe=game.exe
I seem to be getting an issue where the game starts fine but after 20 seconds closes and the Hyperlaunch "now loading page appears"
Any help appreciated
  • Answers 1.4k
Wow, I wonder if these new files will fix my RH loader. That still crashes the game for me. I love testing new files out. Just remember, either backup files before overwriting them or have a clean/untouched version saved someplace else! Made that mistake once, never again! :)
Until you download Rains version of HS2.0 and get a face full of meat spin. :P
The bag is empty and the cat is loose. Your the man with insider knowledge, yes?
But isn't it a sin to mention Two point zero?
dude thats awesome...which key is it and or how you did this?
Thanks
Using the same file you use to assign player 1 keys (config.bat or something like that) click keyboard on the left, select the key you want to use, now on the panel on the right where it says Player 1 start, trigger etc, if you nudge down 3 times from that last entry (Nudge down 3 blank lines) this is the player 2 start bind. I tried binding keys,triggers to the other blank lines to find out which was player 2 trigger but couldn't find anything :(
sig2.png?raw=1sig.jpg?raw=1
Awesome connorsdad!
Ok good news/ bad news. Good News: I found player 2's trigger! It's the blank area right below player 2 start. I verified this by going into test mode where you calibrate the guns. Bad news: The trigger worked, but it said OUTSIDE OF RANGE. I don't have a gun, let alone guns, so I can't test if this would work with a gun.
Awesome connorsdad!
Awesome, why didn't I think of testing that way lol
I have 2 guns, I'll have a play later :)
Sent from my SM-N9005 using Tapatalk
Just curious...I thought my videos were working...but how long is the first video? Mine is like 3 seconds dude in bed then "Shoot, shoot!"
Sent from my SM-N900V using Tapatalk
My videos do that too, I thought that was the norm lol
Fyi, I'm in an arcade on Minehead seafront. It's full of fruities, pusher machines and grabber/ ufo catchers. All they have is Point Blank and a Marksman machine and a few driving games. :( I remember when it was full of the classics.
Have you tried different loader modes ?
-1
2
3
4
5
I did try them all. 2 of them work but they have the same outcome of a zoomed in cut scene. Is this happening to anyone else? Or am I the only lucky one?
I have the sound fix from the post by Grad1us, where is the other fix? I would like to try that too. I noticed my cut scenes re very short. I have the LAV filters and did the ffddshow installed and still no have them real short.
Did you grab and install the sound fix files? If not theres also the 2 channel files which I can Dropbox to you. But try the sound fix files.
Or even to the fix connersdad did
LAV has a tendency to pop up
In the system tray and with particular applications can start up the TTS service. This could be a possibility that causes crash issues. Perhaps looking at disabling the LAV system tray icons from showing notifications etc might help?
Just throwing ideas out there.
It may have been that , but I've since dumped all the codecs and used the sound fix files from mediafire mentioned in the earlier post.
I will try that first. I'd rather not have codecs installed for just one game!
gig, do you not have Lav's pack installed? connorsdad, i need to have my coffee first, but I'll let you know if/once I make some progress.
I finally got the game to load from the Arcade Loader RH file. here I a new problem though. I applied the sound fix, install LAV and FFDShow. if I run the game from the KHSG or KHSG no cursor, it is perfect, I just don't have a crosshair. Sound is great, cut scenes are great. However, if I run if from the Arcade Loader, I get the cursor and it runs fine, but the cutscenes are zoomed into the top left corner. So the first cutscene, where the guy is in bed, I see just the night stand. In the second, when they find their friend, I see a piece of his head. I went through the Config file but cannot figure out which setting to change, if any. Did this happen to anyone else and if so, how did you fix it?
Nah this was Rains 2.0 which was a full screen meatspin. He did it ages ago for April Fools and annoyed a lot of people but was funny as hell to hear about (before my time) Please note that if you don't know what meatspin is googling it is NSFW.
So I had a play and nothing, still says out of screen, even with me waving and shooting my 2nd gun like a mad man.
@connorsdad, does your gun work for player 1 calibration? I only use the mouse as controls for player 1, and the calibration works for that.
Yes mate, works fine.
I think I found it. If I run ForceDisplaySize=0 and DisplayMode=1, I run at the resolution I have set but cut scenes go like I described. If I run ForceDisplaySize=1 and DisplayMode=0, then I get the full window cut scenes but my resolution goes to something like 640X480. You can't set both to 1, it crashes and if you set them both to 0, that sets it to the worse resolution. I tried different loaders but no dice there.
Can I have both? Is there a setting I can change to allow me to force the resolution AND get the full size cut scenes? I guess if not, it is not too big a deal as I would only want to run the Arcade Loader RH file to get the crosshair. I'd rather have a better resolution though so if that is the case, I will just continue use the KHSG file.
-1
2
3
4
5
I had that happen under certain conditions, I'm racking my brain as to what I did to cause it.
Was it something in the ttx.ini?
Was it those dodgy codec packs?
It may be a good idea to start over with a clean install and use the fix files that work for you.
Didn't those 2 channel video files get uploaded twice? The first time they were broken?
Sorry my memory sucks.
