  • 0
Taito Type X and Hyperlaunch 3.0
langersld
Question
I just wanted to get clarification that Taito Type X is working fine in the New RocketLauncher...
In the PC Launcher.ini...I am pointing the script to the bat files
eg:
[super Street Fighter IV]
Application=C:\Hyperspin\Games\Taito Type X\Super Street Fighter IV\Super Street Fighter IV.bat
AppWaitExe=game.exe
I seem to be getting an issue where the game starts fine but after 20 seconds closes and the Hyperlaunch "now loading page appears"
Any help appreciated
  • Answers 1.4k
the control config app doesn't seem to do anything. You have to run 'Game Loader All RS.exe' to get the crosshair to show.
RS or RH? mine came with "Game Loader All RH.exe"
which is what i use and no crosshair.
what about player2 controls?
Thanks
Sorry, typo, it's RH like you said.
Is there an sv folder with a crosshair in it?
Player 2 doesn't work.
yes "CrossHair.cur"
weird :/
have you guys tried deleting the folder and starting fresh? It makes 2 folders in your C:\users\<<username>>\appdata\roaming\ folder, delete those too and try again (Sorry, would be helpful if I gave you the names of them, but im not in front of my Hyperspin PC atm...)
All I do is:
-install LAVFilters
-run the controller config batch, then close it without doing anything.
-install the sound fix (either one)
-run the "Game Loader All RH.exe"
Haven't had the problems you described on either PC's I use.
cant get crosshair to show on silent hill....also cant seem to be abole to set controls for it either via config file it came with....and apparently no player 2 atm?
Controls can be changed with the Config.bat, although it's minimal, I only set Exit and Start.
Device is Keyboard.
From the "Control" section choose the key you want, So i choose "1" for start. Then click or double click 1P_START from the Action box. Do the same for the others.
You can check it's working by clicking the keys you've choosen from the control side and it should change on the Action side.
Hi Guys,
a quick one.
I run Silent Hill from the folder of an separate emulator drive called E:, after going through config the game started to fail at startup and kept attempting to run the game in (was working before). Can someone please conform if the game has actually created local files on C: . The problem went away after I restored my C: from a backup image and as a result cleared anything that potentially was placed there.
Already tried that, no different.
Are you running the KGSW.exe or the loader all RH file? I know for my, mine crashes at the exact same spot yours does if I run that RH file, but plays perfect when I use the KGSW.exe. Yeah, it has no crosshair, but I can deal with that. I am assuming you have already tried running from the KGSW file, but just in case you didn't, try that.
Not sure what OS you are on, but I am on Win7 64bit.
i have crosshair
using the loader all RH
works perfectly fine, my question was around local files created by the game on C: (which i know it does.. somewhere) which can stuff up the game, and this point was proven by me re-imaging my cab back from a image.
using win 7 x64
i think the local files CAN and ARE causing a large number of issues you guys are having by using me as an example.
Ok, done some more testing on this.
Silent Hill runs from either of my Hyperspin Drives (G:\ or Z:\)
The folders that it creates are:
'bemani_config' and 'Game Loader All RH'
located in:
Win7 C:\Users\<Username>\AppData\
WinXP C:\Documents and Settings\<Username>\Application Data\
Delete them if you are having problems and start agin.
Tested both sound fixes, the one from grad1u5 works fine but the sound is out of sync (most noticable is the guy yelling "NoooooO!" in the intro and appearing 2-3 seconds later)
The re-encoded movies from insertmorecoins doesn't seem to fix anything for me?
People having problems with a missing crosshair - are you running this outside of Hyperspin or within Hyperspin? The crosshair is just a windows cursor replacement. If Hyperspin is set to hide the pointer, you prob won't be able to see it...
Anyone else notice the game runs quite slow? doesnt seem to get above 30fps on my i7 4770k, 16GB Ram, GeForce 770 GTX rig.
The enemies seems to move like they are in slow motion. Maybe it needs Triple Buffering to be forced on in the graphics driver to get 60fp? (Will test after work) or it's just not suited to my hardware. Pretty sure thats why the sound is out of sync.
Great job, guy's!
This must be hardware dependant as I don't have the same sync issues.
I think the FPS must be locked at 30FPS, it lagged badly at the start of the game. dropping the res to 1280 x 1024 fixed that.
Thanks for this. Can we get more info on what they contain?
Thanks for your comments.
This is my public folder.
For more information speak don't know English.
Bad English, I'm sorry.
English doesn't matter. Your files helped many people. That is the important thing. Thank you.
cool i got xhair now...had to run it in windowed mode...which means bezel for it coming xD
thanks to all for all the input on this hread...specially gigapig for translating that ttx.ini for us :)
Right, fully figured out Silent Hill on my system and can get it working flawlessly every time i install it.
-You have to install the re-encoded movies otherwise you will get broken cut scenes (like the 'short' intro sequence of the guy in bed then cuts to "shoot, shoot!")
-You have to install the 'sound fix' posted earlier from (http://www.mediafire.com/?wix803bszhyxr) otherwise you get missing sound effects (like the sound thats played when you press the start button)
-The LAV Codec (https://code.google.com/p/lavfilters/downloads/list) is required to view the videos, otherwise the game will crash. Just keep all options default and click next until it finishes installing
-If your using HDMI you will need to force the game to sync to your refresh rate otherwise the game acts strangely (Video's sound out of sync, black screen instead of playing the intro) this is beacuse the game locks the framerate to 24fps (24hz, this is the same problem 'Crysis' has if you use HDMI-out)
to do this, edit TTX.ini and change ForceDisplayRefreshRate=1
All videos working fine now, cursor shows as crosshair until I move the mouse/gun, it then shows as the regular windows mouse cursor :hmpf:
Still, from not working at all to working 90% perfect I'm happy :)
sig2.png?raw=1sig.jpg?raw=1
when i got the game, the CrossHair.cur was in the sv folder and it was giving me issues...i since moved it to the main folder of the game to see...and it works fine now.
I just keep having issues. When I run the game in Hyperspin (and Hyperlaunch), it seems to ignore the TTX.ini file. It does not force resolution, show a mouse cursor or have accurate aim from the gun sights. If I run it outside of Hyperspin, all of this works - resolution is forced and cursor is there. I just don't get it. What could I be doing wrong?
The TTX.ini is used by gameloader RH only. If you use either of the other exe's then you won't get the different res or maybe the cross hair; so make sure in HLHQ the exe path is pointing to the game loader RH.
That's my theory, however I haven't added this game into my setup yet, I or someone will have to confirm that later.
If your cutscenes are working I would leave as is unless it's causing other issues.
If the appwait is required then you can normally find that in task manager, just look for something related to the game, it might be KSHG.exe but I haven't checked.
You could also use the new tool for grabbing the appwait which was added recently to HLHQ, it's similar to the window grabber.
