  • 0
Taito Type X and Hyperlaunch 3.0
langersld
Question
I just wanted to get clarification that Taito Type X is working fine in the New RocketLauncher...
In the PC Launcher.ini...I am pointing the script to the bat files
eg:
[super Street Fighter IV]
Application=C:\Hyperspin\Games\Taito Type X\Super Street Fighter IV\Super Street Fighter IV.bat
AppWaitExe=game.exe
I seem to be getting an issue where the game starts fine but after 20 seconds closes and the Hyperlaunch "now loading page appears"
Any help appreciated
  • Answers 1.4k
I figured out my issue with playing the full cut scenes. I went back and re-read the last couple pages and saw gigapig installed k-lite codes so I went and go the latest version (10.3), which uninstalled the LAV and ffdshow codecs I already had since it has newer ones. I went through and enabled the ffdshow like connorsdad did (I did this before but not all of them were supported - they all are now with the newer version) and now I get the full cut scenes to watch!
I still cannot figure out this screen resize deal and why forcing the screen to a higher resolution forces the cut scenes to be zoomed but no big deal. the game is supposed to run in 640X480 (from what I have read) so I will simply play it like that if I want crosshairs and I can always switch it if I don't want crosshairs.
Ok, So I was able to get Silent Hill playing with cross hair at full screen with full movies/intros minus LAV or ffdshow. I had to use the "2nd" audio files suggested by gigapig. From there I used gig's ttx.ini from his ftp (just as a control; I had messed with mines waaay too much), the only thing I had to mess with was I changed the [Window Size] to =1 then the resolution I changed to my native display 1920 x 1080. Dang, that was fun! Thanks for all that helped!
Nice 1 :)
Hopefully I'll be right behind you.
sig2.png?raw=1sig.jpg?raw=1
All videos working fine now, cursor shows as crosshair until I move the mouse/gun, it then shows as the regular windows mouse cursor :hmpf:
Still, from not working at all to working 90% perfect I'm happy :)
when i got the game, the CrossHair.cur was in the sv folder and it was giving me issues...i since moved it to the main folder of the game to see...and it works fine now.
I just keep having issues. When I run the game in Hyperspin (and Hyperlaunch), it seems to ignore the TTX.ini file. It does not force resolution, show a mouse cursor or have accurate aim from the gun sights. If I run it outside of Hyperspin, all of this works - resolution is forced and cursor is there. I just don't get it. What could I be doing wrong?
The TTX.ini is used by gameloader RH only. If you use either of the other exe's then you won't get the different res or maybe the cross hair; so make sure in HLHQ the exe path is pointing to the game loader RH.
That's my theory, however I haven't added this game into my setup yet, I or someone will have to confirm that later.
Right, fully figured out Silent Hill on my system and can get it working flawlessly every time i install it.
-You have to install the re-encoded movies otherwise you will get broken cut scenes (like the 'short' intro sequence of the guy in bed then cuts to "shoot, shoot!")
-You have to install the 'sound fix' posted earlier from (http://www.mediafire.com/?wix803bszhyxr) otherwise you get missing sound effects (like the sound thats played when you press the start button)
-The LAV Codec (https://code.google.com/p/lavfilters/downloads/list) is required to view the videos, otherwise the game will crash. Just keep all options default and click next until it finishes installing
-If your using HDMI you will need to force the game to sync to your refresh rate otherwise the game acts strangely (Video's sound out of sync, black screen instead of playing the intro) this is beacuse the game locks the framerate to 24fps (24hz, this is the same problem 'Crysis' has if you use HDMI-out)
to do this, edit TTX.ini and change ForceDisplayRefreshRate=1
Where are these re-encoded movies? I don't have them but installing the latest klite gets me the full cutscenes.
Gig and Urban,
I have hyperlaunch looking for the arcadeloader RH.exe to run the game and for the appwait I have tried arcade loader, KSHG and KSHG no cursor and it always launches the same, like the TTX is not there. I run it outside of HS, it runs like it is looking for the TTX.
Has anyone added this to HS yet?
If your cutscenes are working I would leave as is unless it's causing other issues.
If the appwait is required then you can normally find that in task manager, just look for something related to the game, it might be KSHG.exe but I haven't checked.
You could also use the new tool for grabbing the appwait which was added recently to HLHQ, it's similar to the window grabber.
you dont need the LAV codecs at all...all you need is the ffdshow...at least on my end..LAV actually screwed up my system and had to uninstall them, and even then it didnt work so i had to do a system restore...i would suggest to everyone to try ffdshow codecs from here http://www.free-codecs.com/ffdshow_download.htm first before doing the LAV ones.
then open the DSFMgr.exe in your SH folder and if it only shows one ffdshow codec, hit Register new filter and travel to your ffdshow folder and open ffdshow.ax...itll enable all the ffdshow codecs you need.
now just double click on each one and move slider all the way up and click set new merit.
My cutscenes work flawlessly and if youre on win 7....why install unneeded codecs? not worth the hassle.
and please urbangangsta101 dont take this as a cut on you...just stating that LAV codecs arent needed....at least for win 7 ultimate 64 :)
Yeah, sadly enough I'm using windows 8.1 , but I have changed all the exe to run in compat mode for windows 7 ... Still no dice , something tells me I'm S.O.L.
Running as Admin doesn't make a difference either. If it's any help.... it's a boring game anyway...
Final question, with me changing the PCLauncher.AHK (2.0.6 -to 2.1.1), will that break anything else? I did test a few other games and they seem fine, but just curious.
Thanks again everyone!
If you run Steam games, it's currently not working for that, there is a simple fix, but it should be fixed any day; a new script is being tested right now.
Everything else should be fine.
Hello not sure if this is the correct place to post this but I was sent here , any one know what this screen is? This is what I get when I click to start the Silent Hill Arcade game ..post-94279-142870622496_thumb.jpg any info is appreciated
:evil:
Hello not sure if this is the correct place to post this but I was sent here , any one know what this screen is? This is what I get when I click to start the Silent Hill Arcade game ..[ATTACH]38714[/ATTACH] any info is appreciated
Not seen that on my version, although it looks suspiciously like an empty error box. Did it pop up on startup?
You may have an old dump of the game, depending where you got it, I know there is an old one floating around.
Are you using Windows 8.1 by any chance? Does that on my 8.1 PC...
Put this theme together earlier, it's on my ftp folder. Wheel art inside the zip...
http://www.hyperspin-fe.com/forum/showthread.php?31960-Silent-Hill-The-Arcade-Theme-amp-Wheel-Art&p=302462#post302462
:evil:
Has anyone gotten a 2nd gun to work? I think what might be the problem is that the game only reads 1 mouse even though 2 Aimtraks are connected. Now, if I configure the second guns trigger it will only trigger player 1 gun in the test menu.
I have been working on my Taito Type X Collection for the last little while and have my list of troublesome games down to only a handful. Any tips or information on if there is a way to fix it would be greatly appreciated.
BlazBlue Calamity Trigger doesn't want to display the graphics correctly but it is my understanding that unless the graphics card is changed out I'm stuck with and isn't a big deal. Just curious if anyone had any newer updated files that might work that I hadn't found.
Chaos Breaker sits me and black screen and never seems to load anything.
Samurai Shodown starts flashes blue and black quickly and eventually loads. When I go to press the insert coin and start button it basically just don't want to play the graphic and text overwrites itself. The game essentially locks up.
Taisen Hot Gimmick 5 shots back an error box with the word MTS and a whole bunch of characters.
Thanks in advance for any help in getting any of these games to work. I'm always a completionist at heart so I keep working hard and seem to keep getting closer but these few games have proven to be more than a little difficult with downloading multiple versions and still having the problems.
I don't think anyone has the 2nd gun to work. you can set all of the buttons via the config.bat, but without control of the p2 gun, it's useless.
Finally!!! So I had some time to check this out and after looking in the PClauncher.ini file, I notice Silent Hill listed twice! Not sure how that happened but I removed one and pasted Gigapig's settings in and then it prompted me for a [config], which is the second time I had seen that. Pasted a path to each exe and if I used the loader, it would fail while loading, KSHG.exe would have no cursor and KSHG_no_cursor.exe would give me the spinning window wheel for a target... but progress! Then I remembered I had set up GIT for updates just yesterday (finally!). Went and found that PCLauncher had a new AHK so I pasted that in, modified the emulator lists since it doesn't require extensions anymore, then pasted in Gigapig's settings again and voila! Game launched and played with a crosshair! Finally, I can put this one to bed and actually simply enjoy playing it.
Would prolly be better if there was limited ammo... unlimited just makes it a shooter mash em .
Sent from my SM-N900V using Tapatalk
