brolly Posted April 9, 2014 Posted April 9, 2014 *cough* Brolly *cough*.... Did you get a cold or something? Hope you get better soon
Polemicist Posted April 9, 2014 Posted April 9, 2014 Did you get a cold or something? Hope you get better soon Just a slight allergy to old databases. I'm sure I'll find a cure somewhere. ... http://youtu.be/WqzJkTatWiQ
rfancella Posted April 9, 2014 Posted April 9, 2014 ROTF!!! Nice Pole! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Shermo Posted April 9, 2014 Posted April 9, 2014 only difference after checking with 0.152 CHD files btw
mitchm Posted April 10, 2014 Posted April 10, 2014 Hello friends just finished getting the 40gb .153 from PD is it as simple as overwritting my existing roms directory ? Also with the update packs.... the same things applies right... just overwrite and it should update the old and keep the new ? Just making sure this process is correct... cheers.
Rick74 Posted April 10, 2014 Posted April 10, 2014 Is the split set or merged set the way to go? Split set
gigapig Posted April 11, 2014 Posted April 11, 2014 Hello friends just finished getting the 40gb .153 from PD is it as simple as overwritting my existing roms directory ?Also with the update packs.... the same things applies right... just overwrite and it should update the old and keep the new ? Just making sure this process is correct... cheers. Yep you could do that or download them straight into your Mame> Roms folder. Utorrent will check whats in there and only download what is different or missing. Same with the update packs.
showstopper Posted April 11, 2014 Posted April 11, 2014 Yep you could do that or download them straight into your Mame> Roms folder. Utorrent will check whats in there and only download what is different or missing. Same with the update packs. Although this is the easy way it is also the lazy way Running them through clrmamepro deletes all the unneeded files. How to update HyperLaunch
mitchm Posted April 11, 2014 Posted April 11, 2014 Found this tut which was a great help http://www.cphsolutions.f2s.com/guides/cmprotutorial.htm Yes i could of just copy/pasted but your right running through clrmame is the better way because it does proper checks and removed old files.... thanks for the tips everyone.
gadget2k Posted April 11, 2014 Posted April 11, 2014 Hey Guys I have another question it maybe a silly question. But with clrmamepro can you also check other rom sets? Let's say the neo geo cd rom set. I got a dat file from PD and I wanna make sure my set matches up with the hyperspin ready set on PD. [sIGPIC][/sIGPIC]
somail Posted April 11, 2014 Posted April 11, 2014 you can check any set that has a dat file to check it against. I am sure there are exceptions, but I use CLRmamepro for all of my PD based sets.
Dogway Posted April 13, 2014 Posted April 13, 2014 I never got to wrap my mind around clrmamepro, it just isn't how my mind works, I use instead romcenter. Does it make any difference, am I missing something? I wanted to ask, now with MAME 0.153 released, do you think Mame Plus 0.153 is around the corner? I'm converting all my romset to that version, doing work in advance.
Zeaede Posted April 13, 2014 Posted April 13, 2014 I have tried getting into MAME for a while but i can't figure out how to get it work, with the 40gb release i can run some games but with the other releases including the CHD's i think i only mess it up Is there some kind of turtorial with step by step and picture guide how to get it right with all the releases? Thanks in advance
budman Posted April 13, 2014 Posted April 13, 2014 Yep you could do that or download them straight into your Mame> Roms folder. Utorrent will check whats in there and only download what is different or missing. Same with the update packs. tried this but now i have double file names must be doing something wrong same named zip files but have different sizes is there a setting in utorrent ? also ran clrm
y0ul053 Posted April 13, 2014 Posted April 13, 2014 think after running clrmamepro you have to re-torrentzip to start the torrent at a higher completion percentage
Agrajag Posted April 13, 2014 Posted April 13, 2014 http://easyemu.mameworld.info/clrmameguide/clrmame-guide.html The above guide should give you an idea how to use the program, but it also helps to read the guidance in the new release threads on Pleasuredome. The main steps to update MAME from 0.152 to 0.153 (torrentzipped-split set) are as follows (assuming you have read the guide, I'm just giving an overview): 1 - download the Update 0.152 to 0.153 torrent 2 - download the 0.153 DAT file and load it into clrmamepro 3 - set the ROM-Path as the folder containing your full 0.152 set (of which you have a backup, don't you? If not, make one before proceeding!) 4 - set the Add-Path as the folder containing the update pack 5 - Scan and fix 6 - Rebuild, using the Add-Path as the source 7 - you may need to repeat 5 & 6 a few times, using the Backup path as necessary, until you get a complete set 8 - torrentzip the resulting folder full of files 9 - download the 0.153 torrent file, load it into your torrent client and point it at your newly made 0.153 set, making sure to untick the option to start the download automatically 10 - do a Force Recheck and see how close you get to 100%, as it's not always perfect, then start the torrent to download the rest (if applicable) and start seeding. HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
gigapig Posted April 13, 2014 Posted April 13, 2014 I have tried getting into MAME for a while but i can't figure out how to get it work, with the 40gb release i can run some games but with the other releases including the CHD's i think i only mess it upIs there some kind of turtorial with step by step and picture guide how to get it right with all the releases? Thanks in advance Are you asking for a guide for CLRMamepro or setting Mame up for Hyperlaunch/Hyperspin?
Dogway Posted April 15, 2014 Posted April 15, 2014 I wanted to ask, now with MAME 0.153 released, do you think Mame Plus 0.153 is around the corner? I'm converting all my romset to that version, doing work in advance. Also curious to know how to disable Joystick on GUI in M+GUI. I can do it in Mame Plus through Interface Options but no clue on M+GUI. And I want to ask, how do you configure default joystick buttons? I configured the default.cfg file inside the cfg folder with my mappings, but everytime MAME crashes (quite often) the content of the file is just removed and I lose all my keymaps. I read you are not supposed to write anything onto that file, but then how do you do it?
16bitHero Posted April 15, 2014 Posted April 15, 2014 How hard is it to update from .151 to .153 rom set?
somail Posted April 15, 2014 Posted April 15, 2014 If you know how to use CLRmamepro then about 5 mouse clicks and an hour of cpu time.
sreisig1 Posted April 16, 2014 Posted April 16, 2014 So split set is way to go on PD? Whats the difference between merged and split? Also, The 40GB for 0.153 on PD doesn't include CHD files. Is that somewhere else. How would I update CHD files.
Agrajag Posted April 16, 2014 Posted April 16, 2014 This info can all be found on PD. Look in the wiki and read the ROM and CHD release threads. The split set is recommended for HyperSpin. HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
