gigapig Posted February 9, 2020 Posted February 9, 2020 On 2/9/2020 at 5:14 PM, goofers said: Any chance of a new build that suports Win10, I have not used Hyperspin in over 2 years because of this?? Expand The 1.5.1 build has supported Windows 10 for the last 2 years.
fr0stbyt3 Posted February 10, 2020 Author Posted February 10, 2020 On 2/9/2020 at 5:14 PM, goofers said: Any chance of a new build that suports Win10, I have not used Hyperspin in over 2 years because of this?? Expand We're here to help if you find an issue with 1.5.1
dark13 Posted February 10, 2020 Posted February 10, 2020 Can someone please link me HyperSpin.exe 1.5, the first version working on w10 1809? I'm doing some tests but I don't have that version, thank you very much. Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
ninja2bceen Posted February 11, 2020 Posted February 11, 2020 No issues here on windows 10 latest update Sent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
fr0stbyt3 Posted February 16, 2020 Author Posted February 16, 2020 On 2/11/2020 at 10:55 PM, ninja2bceen said: No issues here on windows 10 latest update Sent from my iPhone using Tapatalk Expand Same. I tested and both HS and HT work on 1909
Creezz67 Posted February 17, 2020 Posted February 17, 2020 Same here, all running fine on latest updates.
KaaMoS Posted March 18, 2020 Posted March 18, 2020 On 2/16/2020 at 10:56 PM, fr0stbyt3 said: Same. I tested and both HS and HT work on 1909 Expand Sorry if I'm being itchy, but I'm facing this problem with Windows 10 (X64) build 2004. Version 1.5.1 was working ok until this Windows update got installed. Same problem, same synthoms. I have no clue about how to make HS run, process is killed by itself and window doesn't even open. Please, any help is well received.
fr0stbyt3 Posted March 18, 2020 Author Posted March 18, 2020 On 3/18/2020 at 2:25 PM, KaaMoS said: Sorry if I'm being itchy, but I'm facing this problem with Windows 10 (X64) build 2004. Version 1.5.1 was working ok until this Windows update got installed. Same problem, same synthoms. I have no clue about how to make HS run, process is killed by itself and window doesn't even open. Please, any help is well received. Expand To help you diagnose this: - First download a fresh copy of 1.5.1 and assure that it fails as well. - Make sure any virus protection still has an exemption for hyperspin - Post your full windows version number run winver and it'll show you
KaaMoS Posted March 19, 2020 Posted March 19, 2020 On 3/18/2020 at 3:33 PM, fr0stbyt3 said: To help you diagnose this: - First download a fresh copy of 1.5.1 and assure that it fails as well. - Make sure any virus protection still has an exemption for hyperspin - Post your full windows version number run winver and it'll show you Expand Hi, fr0stbyt3, Thanks for your reply! I have this: 1) First step: Verified. Failed. 2) Second step: Windows Defender already had exceptions for HS and other related apps. Checked again, still there. 3) HS 1.5.1 was working OK before WIndows 10 updated to version "2004 (SO build 19582, 1001)". Info was taken from winver, as you suggested. Some other Symtoms: * Once System was updated, HS just didin't launch, if I check Task Manager, I can see how HS loads, but then gets killed. * If I run HS in compatibility mode, all older versions have shown the same result, with the exception of Windows XP SP3, which shows a message error related to 0xc000005. Now I'm in your hands, if you need some other info, please tell me. Thanks again! I'll stay tuned!
Gothicplsur Posted March 24, 2020 Posted March 24, 2020 I've been running HS for years and updated to 1.5.1. My PC is currently updated with recent windows updates. My suggestion is to go to the HS folder you have it in right click on the HS.exe - go to compatibility and checkmark 'run as administrator'. then give it a try. I suggest you do the same to Hyperlaunch, Rocket Launcher, and hell even HQ, and Hypersync.
matty_g_8 Posted March 27, 2020 Posted March 27, 2020 Hi All, A few years ago I updated my arcade to hyperspin 1.4 and rocketlauncher. I have had to rebuild it but have a back up of my hyperspin setup, Is it work just updating to 1.51 whilst i am at it? Would all I need to do is copy over the updated .exe files? Thanks
fr0stbyt3 Posted March 27, 2020 Author Posted March 27, 2020 On 3/27/2020 at 12:05 AM, matty_g_8 said: Hi All, A few years ago I updated my arcade to hyperspin 1.4 and rocketlauncher. I have had to rebuild it but have a back up of my hyperspin setup, Is it work just updating to 1.51 whilst i am at it? Would all I need to do is copy over the updated .exe files? Thanks Expand I would backup main directory but all of the EXE files should do it!
goldiemike Posted April 3, 2020 Posted April 3, 2020 On 3/19/2020 at 5:50 AM, KaaMoS said: Hi, fr0stbyt3, Thanks for your reply! I have this: 1) First step: Verified. Failed. 2) Second step: Windows Defender already had exceptions for HS and other related apps. Checked again, still there. 3) HS 1.5.1 was working OK before WIndows 10 updated to version "2004 (SO build 19582, 1001)". Info was taken from winver, as you suggested. Some other Symtoms: * Once System was updated, HS just didin't launch, if I check Task Manager, I can see how HS loads, but then gets killed. * If I run HS in compatibility mode, all older versions have shown the same result, with the exception of Windows XP SP3, which shows a message error related to 0xc000005. Now I'm in your hands, if you need some other info, please tell me. Thanks again! I'll stay tuned! Expand Good day peeps. I am new here and have run into the same issue and was wondering if there was a fix to this. I am running Windows 10 Version 2004 (OS Build 19041.153). Thanks in advance.
Rayne Posted April 4, 2020 Posted April 4, 2020 Good Evening. Not to sound like a broken record after hunting the forums and the web on this issue, but is the "Search Subfolders" issue gonna be fixed at any point in the near future? I'd rather not have large game files zipped as they take way too long to launch and don't want the custom trimmed XML as I'm constantly adding games as I see the need/want. I'd appreciate any updates you may have on this.
Spawk Posted April 4, 2020 Posted April 4, 2020 On 4/4/2020 at 2:45 AM, Rayne said: Good Evening. Not to sound like a broken record after hunting the forums and the web on this issue, but is the "Search Subfolders" issue gonna be fixed at any point in the near future? I'd rather not have large game files zipped as they take way too long to launch and don't want the custom trimmed XML as I'm constantly adding games as I see the need/want. I'd appreciate any updates you may have on this. Expand Hi Rayne, Can you be specific on what system(s) you are having issues with? You have options. I am also in the midst of converting all my zip collections into more usable formats (CHD, PBP, etc). All of which have nearly as good compression as zip and load as fast as an iso. Also if space is no problem at all, you can always just leave them un-compressed. Just have them all in 1 folder. For systems that have games that use same names (track 01, track 02), put them in folders, just make sure that the folder is also named exactly like the database.
Tranzior Posted May 10, 2020 Posted May 10, 2020 Hi guys, I am running Windows 10 pro x64 Version 2004 (OS Build 19041.208) and have absolutely the same issue after windows Update HypeSrpin 1.5.1 just crashes after launching. It was working fine before windows update, could not find any logs to find out the reason of crashes. Compatibility mode with all previous Windows versions, running as Administrator does not help. Right now I am about to update Windows to the latest Beta to check if this would help me. Is there are any options to run the HyperSpin in debug mode? Thanks in advance
Gothicplsur Posted May 11, 2020 Posted May 11, 2020 I noticed that sometimes when I go to Task Manager an instance of Hyperspin or sometimes a couple Hyperspin are running in the background, even sometimes HyperHQ if I've been working with that keep HS from launching. I'm current with my Windows updates constantly and never had a problem with running HS. I do have it running as administrator from the .exe "properties". Only thing I would suggest if you haven't tried already is re-download Hyperspin 1.5.1 place it for now on the desktop and running that fresh .exe to see if it runs. Another thing I suggest which may or may not be the issue, uninstall and instance of "Java" from your machine, from the add/remove list of programs. Hope that helps.
Tranzior Posted May 11, 2020 Posted May 11, 2020 On 5/11/2020 at 2:24 PM, Gothicplsur said: re-download Hyperspin 1.5.1 Expand is not helping getting the same error, uninstalling Java does not help as well Here is the log which i can get from AppCreashView tool: Exception Code: 0xc0000005 Fault Module Name: ntdll.dll Fault Module Version: 10.0.19624.1000
braap Posted May 11, 2020 Posted May 11, 2020 On 4/4/2020 at 7:02 PM, Spawk said: Hi Rayne, Can you be specific on what system(s) you are having issues with? You have options. I am also in the midst of converting all my zip collections into more usable formats (CHD, PBP, etc). All of which have nearly as good compression as zip and load as fast as an iso. Also if space is no problem at all, you can always just leave them un-compressed. Just have them all in 1 folder. For systems that have games that use same names (track 01, track 02), put them in folders, just make sure that the folder is also named exactly like the database. Expand That doesn't work. For multi disc games that need to be unzipped (PS1), HyperHQ needs a file extension. Typically this would be .cue but since it won't look within sub folders it's pointless. On 5/11/2020 at 2:24 PM, Gothicplsur said: I noticed that sometimes when I go to Task Manager an instance of Hyperspin or sometimes a couple Hyperspin are running in the background, even sometimes HyperHQ if I've been working with that keep HS from launching. Expand These have both been issues for years and hasn't been fixed. As for searching subfolders, don't hold your breath. I have a .bat script run when HS closes that forces all Hyperspin.exe instance to close.
Spawk Posted May 12, 2020 Posted May 12, 2020 On 5/11/2020 at 11:02 PM, braap said: HyperHQ needs a file extension. Typically this would be .cue but since it won't look within sub folders it's pointless. Expand HyperHQ? ...ALL launching should be done by RL. HQ is only really useful for populating/filtering the wheel! You can create dummy text files and use the txt extension if you want. It will have no effect at all on launching. RL will load them fine.
Spawk Posted May 12, 2020 Posted May 12, 2020 On 5/11/2020 at 4:48 PM, Tranzior said: is not helping getting the same error, uninstalling Java does not help as well Here is the log which i can get from AppCreashView tool: Exception Code: 0xc0000005 Fault Module Name: ntdll.dll Fault Module Version: 10.0.19624.1000 Expand Ouch, ntdll errors can be almost anything! Have you got the latest .net framework?
Tranzior Posted May 12, 2020 Posted May 12, 2020 On 5/12/2020 at 4:58 AM, Spawk said: Ouch, ntdll errors can be almost anything! Have you got the latest .net framework? Expand .NET Framework 4.8 is already installed, is there any way to get detailed launching logs?
Bubs Posted May 14, 2020 Posted May 14, 2020 Hi, I just realized version 1.5.1 a new behavior when HyperSpin is setup to be launched on Windows Startup (replacing explorer) : It do not accept anymore relative paths when setting Working_Directory in [Startup Program] section of the settings.ini.... Only Absolutes paths can be used which makes my setup less portable ... Does anyone noticed the issue and had found a workaround? Thanks Upgrade you Frontend arts with the new Vector Pack ! -> Download Here
Creezz67 Posted May 18, 2020 Posted May 18, 2020 Just wondering if anyone is looking into this issue with Windows 10 (X64) build 2004 ? This is a May 2020 update so will probably roll out to all computers soon, so everyone will be in the same boat soon and nobody will be able to load Hyperspin.
