HyperSpin 1.5.1 Public Release
fr0stbyt3
i really happy to see development move on ..:)
i prefer if there  more support for video themes
i try to display menu interface image  ,i can see  icon but menu work behind video theme .
HYPERSPIN 1.5.1 WELCOME
  • Replies 341
1 hour ago, tspkelleher said:
hi can some one help me where do i put these files on the drive or the desktop top
In your HyperSpin folder. I'd imagine whatever is on your desktop is just shortcuts to the applications in the folder on the drive.
When I update Hyperspin to de 1.51 release, the windows Defender says that is a virus and block the files of Hyperspin.exe and HyperHQ.exe
Have into the files a virus? Is a good update?
Thanks.
Hypertheme is not remembering which zip (theme) it opened. Thus u have to save theme as entire new file then copy back to where original one is loaded from..kinda a anoyance
Afaik hypertheme has not been touched in this release or for a few years
Alright, but it was working fine before 1803 and update for it.Its impossible to edit theme right now , u have to save new theme every time
Only just spotted this thread and great news on a new release! When I click the links in the first post however I get link doesn't exist - have the files moved?
Sent from my Mi A1 using Tapatalk
No,  still there.
On 03/06/2018 at 9:34 PM, dangerranger96 said:
Is anyone else getting an issue with rocket launcher? Hyperspin won't launch games after the update (or full install). The log file says it can't find hyperlaunch in the path. I have the rocket launcher exe renamed to hyperlaunch but it says it can't find it. I reset all the paths in hyperHQ but that did not work either.
What the hell are you doing? Rocketlauncher is ROCKETLAUNCHER for a reason, you just rename where it says c:\hyperlaunch to c:\RocketLauncher
It is hardly rocket science is it?
Proud to be part of the Hyperspin community.
On 6/17/2018 at 2:20 AM, thatman84 said:
I would have to run all my images through a PNG to JPG converter then back again to find out. It wasn't simply the center image that gets skewed, however. The other images are all somewhat moved to the right and the top of the larger center image starts at the same position as the smaller images. It's all out of whack. In any case, it's real difficult to test since I use Sophos AV. Sophos freaks out over the new Hyperspin.exe files regardless of how much I tell it to ignore the files and folders. It wipes out the files almost instantly.
Could you not just do one or 2 images to prove/disprove the theory? I understand the annoying AV thing may put you off though.
I converted about 20 images to JPG then back the PNG but can't get the new Hyperspin to even download now. Everything is turned off but I guess Malwarebytes and/or Sophos is running the background. I can give you the D&D system complete archive with the new converted images to test with if you'd like. You'll have to set it up as per the instructions. The link to the HyperspinHQ setup is
So this contains everything without any changes? That would be the best starting point.
let me know
let me know
Well, that's the system files. You'd have to download the wheel images and the other component separately. I can provide you with an archive with all components of the system all ready to go if you'd like .
In order for me to attach here, I included only about half the original images in the originals folder plus about 20 that were converted from PNG to JPG back to PNG. If you want the whole system let me know. Thanks!
Dungeons_&_Dragons_Hyperspin_-_Complete.rar
So I tested this on my Windows 8.1 machine as don't have 10 on anything.
1.5.1 Hyperspin Upgrade files applied
This is with the above pack (20 Converted Wheel Images)
This is with the Original Wheels copied into main wheel directory
So it proves that there is a difference in how 1.5.1 reads jpg files renamed as png?
I don't expected this will get a much time if i'm being honest but @jhabers would need to comment
Thanks for doing this @thatman84  I will begin bulk converting all the files from PNG to JPG then back to PNG; although I don't remember saving JPGs to PNGs originally. The next step is to get Sophos to play nice with these files but I don't expect that to be an easy task.
