Big Bang Pin - 46/30/15.6 LED Widebody (custom artwork, bezel less, deep playfield)
chriz99
Hi All,
I'm fresh on the forum, but already been reading a lot "in stealth mode" ;-)
first of all Chriz99, superb job on the build, to be honest, you are my inspiration to start one myself...
I'm now looking at building my own widebody cabinet (thanks mameman for the measurements of it). I would go for a 46" playfield, backbox with 30" and dmd screen (not yet clear for me what to use)
I already have a first question. on the build of maneman, the screen is on top. I do like the deeper playfield more, so I like your option chriz99. just looks more original, I might give it a small slope I think. (2 degrees or so)
But as normaly it is on top of the full width, did you make the cabinet a little wider chriz99 to keep it inside??
if there are more people of belgium, please don't hesitate to contact me, as I will need a lot of help on the PC and programming side... hardware of the cabinet build and other stuff will be ok to do...
for sure till later ;-)
ciao,
Shibbynator
  • Replies 803
hey ron, check out these pics:
installed original flipper buttons (crystal clear) with leaf switches and bent a selfmade LED holder for button illumination. got the RGB-LED boards from wolfsoft.de
Thank you sir.
...I already have a first question. on the build of maneman, the screen is on top. I do like the deeper playfield more, so I like your option chriz99. just looks more original, I might give it a small slope I think. (2 degrees or so)
But as normaly it is on top of the full width, did you make the cabinet a little wider chriz99 to keep it inside??...r
hey Shibbynator, for original bally/williams widebody cabinet size you have to buy an UE46/UN46 series Samsung slimline LED TV. besides that, you need to route 2 slots sideways in the cab - to slide in the screen. I have posted some pics in this thread.
cheers
chris
[sIGPIC][/sIGPIC]
Yup, echo what Chris says on the screen. Dr who was flat on top like Chris sttng. Also checkout the BBB thread in my sig for the routed lower version for pics. You really need to run around 6 degrees for a good effect.
Hi All,
ciao,
Shibbynator
CNC Work Here.....
Hi Chriz99.
this seems to be a rather expensive choice compared with several other LCD screens. What's the reason why this has to selected? size?
Another question your SSD of 64Gb, is this sufficient to run all tables and software?? or is extra HD space needed?
Hi Mameman, To be honest I was planning to make the playfield/screen lowered in the cabinet but still make it tilted on some degrees... :-)
Thought I would be the first to have this done ... euch NOT :-)))
Hi Chriz99.
the reason for the UE46/UN46 was because no other confirmed LCD-TV fits "inside" a standard widebody cabinet.
64gb SSD is more than enough. I used a 32gb SSD before, but I love the faster speeds of the new 64gb one (100mb/s : 500mb/s)
cheers
chris
[sIGPIC][/sIGPIC]
Hello Shibbynator and welcome to the forums.
I'm from Belgium too, Charleroi to be precise, I'll start to mount my cabinet soon, I am just waiting the virtuapin parts (buttons and cabinet parts).
Would be glad to help, Chris help me A LOT already so I'm not a total beginner anymore :)
On pc and programming I can almost handle by myself, it is more the build of the cabinet itself that will cause me more problems.
We certainly can share our knowledge ;)
how deep were the slots you made? did you use 18mm MDF?
Just one question how do you know the inside width of the TV without the plastic sides?
Hi Arngrim, nice to meet you, for sure we can share knowledge. I'll be glad to help on the cabinet side... where did you get your parts? did you buy them new?
I think the routing was 10mm deep, I used 19mm MDF
thats the 1 mio $ question :D
It's simply try and error. buy a tv, decase it and measure the metalframe... and hope that it will fit :reddy: mameman found out that the UE/UN46 series fits like a champ :five:
Chris, what is the wire management solution you have called, it looks real slick.
you mean the cable canal?
it's called "slotted cable trunk". can be found on ebay or electronic stores.
cheers
chris
[sIGPIC][/sIGPIC]
Shibbynator,
Français or Vlaams ? ;)
I bought the cabinet and button parts from Virtuapin.net.
I'll go for a 40",32", and temporary a 15" until the real dot matrix project comes to his end :
http://www.vpforums.org/index.php?showtopic=17294&st=0
I'll design the cabinet with google sketchup, and send the dxf's to a shop near my home.
My biggest problem now, for the glass of the backbox, the trim of virtuapin.net will certainly be smaller than my 32", so I'm not sure how to handle this yet, I have to ask Mameman with his Big Bang Bar build.
I'll create a topic once the cabinet is built.
the real dot matrix project is really cool, but I think I can't live without the "yellow simpsons", "green attack from mars" and "pink cirqus volraire" dmd anymore :D
cheers
chris
[sIGPIC][/sIGPIC]
Angrim,
Vlaams, I'm from Kortrijk
hard to find a 30" indeed, I was looking for a 32" too... where did you get that 15,6"?
I was thinking to widen the backbox if I can't find a cheap 30". Should not be such a hard deal if you make the cabinet yourself. Even the glass is not a big issue, just search for a local glass worker ;) concering the trim, I'm sure there can be found a solution for that too...
Thanks! I really like how organizer your wiring is around the components. Will try this with a combination of the corrugated tube for long runs.
hey chriz, happy new year!
Are you sure that any of the UE/UN46 series fits? Even the cheaper ones from the 5000 series?
Bitbuster
hey ryan, happy 2012 :beer:
I think that every UN/UE46 will fit... but 100% guarantee only for the approved/pretested models. Just try the 5000 series and report back, so everyone can profit from your information.
cheers
chris
[sIGPIC][/sIGPIC]
ordered a bunch of pixel's pcbs:
some driver boards
some shifting boards
can't wait for these toys :D
great work erwin! you're a real solder demon :five:
first WIP pics ;)
cheers
chris
[sIGPIC][/sIGPIC]
Based on your setup and current number of toys how any driver boards and multiplex pcbs are you thinking of adding?
To know, is to know that you know nothing. That is the meaning of true knowledge.
