Zablon Posted April 7, 2012 Posted April 7, 2012 I have admit, I'm considering putting a filter over mine. It is so bright and puts such a reflectoin off the playfield glass, it makes it hard to see the upper playfield on DMD tables many times...
chriz99 Posted April 7, 2012 Author Posted April 7, 2012 thanks guys no filter here, just the normal plexiglass on the speakerpanel itself. It's hard to catch the right color and effect with the cam. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
gbeef Posted April 7, 2012 Posted April 7, 2012 Ok thanks I just put a filter over mine. My DMD is too blinding. My Cabs My Pin Cab Attack of the PINZ cab My Racing Cab OutRun Racing
rotoforever Posted June 3, 2012 Posted June 3, 2012 painted today with a 2in1 primer+paint combo (black matte satin). I love the look and feel. Sorry to revive this old topic, just spent the whole weekend going through these amazing build threads. Thanks for posting all this great information, very useful for a total beginner like me. The paint job on this cabinet is astonishing. Very smooth surface. Did you use rollers? How many layers? Did you sand it after each? What paint brand did you use? Thank you! My Tron:Legacy Build Thread
mameman Posted June 3, 2012 Posted June 3, 2012 Not sure how Chris applied his in the end. I know we talked way back about how I do it. Simply a 4" foam ( no nap) roller. PM me for any custom CNC needs. Find me on Facebook.. Xtreme Pinball or www.xtremepinball.com Ipad pinball cabinet iFlipper Here: See the Doctor Who build Here.... / See the Tron build Here.... / See the BattleStar Galactica build Here.... See the Big Bang Bar build Here.... / See the Twilight Zone build Here.... CNC Work Here.....
chriz99 Posted June 3, 2012 Author Posted June 3, 2012 yes, I used a very good quality roller and a primer&paint combo (brand was "genius"), 2-3 layers, sanded a little bit between the layers. thats it also the surface of MDF wood is very smooth and helps to get a nice and clean painting. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
kronic24601 Posted June 7, 2012 Posted June 7, 2012 Hi Chris, Quick question for you. I'm trying to build a similar setup as you and I'm curious how you setup your LED Wiz. 5 RGB Crees - 15 Outputs 8 Contactors - 8 Outputs 2 Flashers Playfield - ? Outputs 2 Flashers Bottom - ? Outputs 4 Flashers Backbox - ? Outputs 1 Gear/Wiper Motor - 1 Output 1 Shaker Motor - 1 Output 1 Original Pinball Knocker - 1 Output 2 Fans - 1 Output 5 Admin Buttons - 5 Outputs ?? 4 Flipper RGB Buttons - 12 Outputs? 1 RGB Strip under cab - 3 Outputs? ... I'm either missing something, or you are using two LedWiz controllers right? I'd love to understand your setup a little better if you are just using 1 LEDWiz ... if that's okay with you... My Evil Arcade Monkey shakes when ever I'm having arcade problems ... notice how he is always shaking
JaronSenna Posted June 7, 2012 Posted June 7, 2012 Hello Chris, I went through the thread again, but did not find what I was looking for. Please excuse me if it has been explained and I missed it, but I read you used illuminated flipper buttons for dedicated button colours. While I understand how to connect the electronics, I wonder how you set/configure the colours for the buttons to match the colours on the original cabinets? Jaron my pincab build thread
bill55 Posted June 8, 2012 Posted June 8, 2012 Hello Chris,I went through the thread again, but did not find what I was looking for. Please excuse me if it has been explained and I missed it, but I read you used illuminated flipper buttons for dedicated button colours. While I understand how to connect the electronics, I wonder how you set/configure the colours for the buttons to match the colours on the original cabinets? Jaron If you use Pixel's LEDWiz config tool the button colors are already set in the table config's. Bill My Pinball Build: Indiana Jones and the Pinball Crusade
Shibbynator Posted June 8, 2012 Posted June 8, 2012 Hi Kronic, is it the idea to use all separate? From my side I'm doing this : 1> all flashers on 1 output (I only have 4 and use ledwiz booster board) 2> fans directly on psu so they are always on, no need to get this controlled I think 3> flipper RGB + RGB cab strip on 3 outputs (again on ledwiz booster board) 4> I only control 2 admin buttons, the remaining are directly on psu also to have them always on I also have 5 RGB leds, 8 contacts, gear motor, shaker motor and replay knocker. ledwiz board is full but no need to have a second one... hope it could help a bit... Hi Chris,Quick question for you. I'm trying to build a similar setup as you and I'm curious how you setup your LED Wiz. 5 RGB Crees - 15 Outputs 8 Contactors - 8 Outputs 2 Flashers Playfield - ? Outputs 2 Flashers Bottom - ? Outputs 4 Flashers Backbox - ? Outputs 1 Gear/Wiper Motor - 1 Output 1 Shaker Motor - 1 Output 1 Original Pinball Knocker - 1 Output 2 Fans - 1 Output 5 Admin Buttons - 5 Outputs ?? 4 Flipper RGB Buttons - 12 Outputs? 1 RGB Strip under cab - 3 Outputs? ... I'm either missing something, or you are using two LedWiz controllers right? I'd love to understand your setup a little better if you are just using 1 LEDWiz ... if that's okay with you...
chriz99 Posted June 8, 2012 Author Posted June 8, 2012 hey kronic24601, you can see my ledwiz config at pixels site. simply load my "chris2" config. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
kronic24601 Posted June 9, 2012 Posted June 9, 2012 Hi Chris, Thanks for the tip. That was certainly a help. However, I have 2 questions for you. 1) There was only one input for the stroboscope section, so are you then combining all strobes in parallel? (2 under cab, 2 in play field, 4 on top of backbox) 2) You had the awesome idea to add Fans behind your speakers for certain games that use this (whirlwind, ect...). Are you no longer using them, or did you find a way to fire that off without using the LEDWiz? Thanks so much... after 74 pages of this forum I'm sure you are done answering questions My Evil Arcade Monkey shakes when ever I'm having arcade problems ... notice how he is always shaking
chriz99 Posted June 10, 2012 Author Posted June 10, 2012 yes, the strobes are wired parallel, so you need only 1 ledwiz port. the fans are wired parallel to the shaker, due to the lack of free ledwiz ports. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
evil eye Posted June 10, 2012 Posted June 10, 2012 So does that mean the fans only work when the shaker is activated? In other words, they both turn on and turn off together?
chriz99 Posted June 10, 2012 Author Posted June 10, 2012 if you connect the fan parallel to the shaker, they both turn on and off together. If you have another free port on your ledwiz, you can connect your fan separately. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
Bitbuster Posted June 20, 2012 Posted June 20, 2012 Sorry guys, I didn't find to the time to finish my project yet. So I couldn't test out the cheaper Samsung LCD TVs. But now I have almost all parts together except the TV. When I was shopping around for the D6200 model I stumbled across the new "E"-Series from Samsung, especially the UE46ES6300. Could this be the sucessor to the D6200? Since they are about the same price I would rather go for the new model..
Gigagamesguy Posted June 20, 2012 Posted June 20, 2012 Hi yes the ue46es 6300 is a New Model in the year2012 Samsung called the New Ones with an ES in the Name. Its Good to Buy the older Model from 2011 for a cheaper price http://www.hyperspin-fe.com/forum/showthread.php?16722-New-PowerPin-from-Germany-Tom-46x32x15-6
Bitbuster Posted June 22, 2012 Posted June 22, 2012 Strangely the D6200 is still more expensive than the ES6300..
eimer205 Posted June 26, 2012 Posted June 26, 2012 Hello Chris, thank you very much for the inspiring documentation of this great cab. May I ask one question: I'm preparing to build my own cab so I have bought the Teufel soundsystem C 200 USB and doing some testing. Now every time I'm switching off the power and restarting the system the Teufel system is in standby mode. I have to press one of the two power buttons of the system. Have you had the same problem? Have you solved this problem? A solution is to get the remote control of the soundsystem with one of the two power buttons to the outside of my cab but this is not my preferred solution. Best regards, Stefan.
chriz99 Posted June 26, 2012 Author Posted June 26, 2012 hey stefan, yes, thats a little problem with the teufel C series. you have to press the ON button after switching the power off/on. It's no prob for me because the sub is located at the front, so I can easily press the ON button. alternatively you can tape down the ON button with strong self adhesive tape. I have tested it and it works like a charm, but I have no idea if this "hurts" the electronic of the subwoofer board (in the long term). cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
eimer205 Posted July 3, 2012 Posted July 3, 2012 hey stefan,yes, thats a little problem with the teufel C series. you have to press the ON button after switching the power off/on. It's no prob for me because the sub is located at the front, so I can easily press the ON button. alternatively you can tape down the ON button with strong self adhesive tape. I have tested it and it works like a charm, but I have no idea if this "hurts" the electronic of the subwoofer board (in the long term). Hello Chris, thank you for your answer. I think i will install another power-on button at the inside of the front of my cab and place the sound remote control near this button. May I ask another question: Introducing you have written about new playfield and backbox glasses. Safety glasses. Are these glasses coated ("entspiegelt")? Where have you ordered your glasses? There are some nice offers at the internet for safety glass ("ESG" glass) but it is not coated. So I'm thinking about the playfield glass. Is a standard pinball playfield glass coated or is it not? What do you think? Any experience? Best regards, Stefan.
chriz99 Posted July 5, 2012 Author Posted July 5, 2012 IMO you don't need coated glass on a virtual pinball machine. I love the minimal, extra reflections with standard glass (LCD, flashers and so on). gives a little more 3D feeling cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
85vett Posted July 6, 2012 Posted July 6, 2012 I agree with Chris. Just be sure to get tempered glass as it's going to be safer to use.
gbeef Posted July 6, 2012 Posted July 6, 2012 Very nice effects with the ground LED's chris.. I can believe how big this thread is.. So for DMD are you going back to LCD? My Cabs My Pin Cab Attack of the PINZ cab My Racing Cab OutRun Racing
